Cambridge Audio Azur 640a problem
Old 2nd June 2013, 02:02 AM   #1
Peeb is offline Peeb
Default Cambridge Audio Azur 640a problem
There is an intermittent problem with the speaker output. When switching between input source there is either no sound or it only comes out of one channel (can be either) or it works properly.
When pressing the input selector button there is the expected audible (relay?) click inside the amp. If I keep switching between inputs it will eventually work although sometimes one channel can drop out later. It seems to work better if it is warmed up. It's been happening for years but is getting worse to the point of unusable. Can take 20 or more switches to work.
I only use one input channel and have moved the RCA's around all 4 inputs with no improvement.
Is this something easily (cheaply) fixed by a technician or is a new amp (AU$500) the solution?
Cheers
Old 2nd June 2013, 01:50 PM   #2
Possibly dirty contacts in the selector switch/es
Disconnect from the mains power.
Inject switch cleaner inside the switch and operate repeatedly.
Allow time for all the solvent to evaporate before considering reconnecting to the mains.
regards Andrew T.
Old 11th June 2013, 04:45 PM   #3
numb erone is offline numb erone
I have a similar problem with my Azur 640a. In my case it's a contact issue in the balance dial. It just needs to be re-welded.
Old 11th June 2013, 05:13 PM   #4
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Welding PCB boards is the ,most epic thing ive ever heard.
Only possible in china
Old 11th June 2013, 05:45 PM   #5
overall feedback is offline overall feedback  Croatia
Cheers
Indeed it could be cold solder, try resold contacts on input signal path, relay included if exist there.
Old 15th October 2013, 05:57 PM   #6
androa76 is offline androa76  Slovenia
Hello,
I will ask here, and i am sorry if this is the wrong place.
I am owner of Cambridge audio amplifier 640v2
After 7 years stops working.... some material was blown...including 7805 and....programed PIC controller. I have contacted original service for spare part and also direct Cambridge audio, but nobody want to help me... i wait and wait but no answer. Cambridge support says that they are not competent to give this info...
Can anybody help me please!!!!
I need Programed PIC... in service manual is written...
PY635 PIC16F721/SP Flash PIC micro Factory part4116-720054-200 1 U2
U2 must be programmed
with AP18951/1 software
(file name: 640AV2.hex)
Request from UK Office
Ok go step by step...if somebody have 640AV2.hex file is also enough because i know somebody who can programme me PIC...
The next possibillity is that somebody who have 640V2 try to copy Firmware from original PIC... if it is not protected to read...i hope so...because i am sure that is protected to written.
I am very gratefull for any help or any kind of information of this PIC spare part.
Davorin Slowenia
Old 15th October 2013, 06:03 PM   #7
Mooly's Avatar
I think the chances of anyone just having a hex file for the PIC are non existent tbh.
Surely the part is available when ordered via the part number in the manual.
Although your PIC is faulty is there any chance that the data can still be read... worth trying maybe.
Old 15th October 2013, 06:17 PM   #8
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
Mooly, most PICs have a protection bit that stops anyone reading and stealing the code from them.
Cambridge Audio might have the .HEX file though.
Old 15th October 2013, 06:21 PM   #9
Hello...
Any idea where??? original service in Slowenia can not get it...
Maybe some diy servicer or member of diy who repaire audio equipment.
Pic is dead, supply and gnd is in conntact....therefore te 7805 is hot in 10sek.
Thank you
Davorin
Old 15th October 2013, 06:32 PM   #10
Mooly's Avatar
Thanks... now you mention it I remember.
Have you tried Cambridge Audio in the UK,
Cambridge Audio Customer Care Centre
Cambridge Audio Azur 640a problemHide this!Advertise here!
Cambridge Audio 640A Overheating / Distortion nickalmond Solid State 40 17th May 2013 12:46 AM
Cambridge Audio Azur 640A v2 problem kynsi Solid State 3 9th October 2011 10:15 PM
Cambridge Azur 640A V1 Buzz leviathon Solid State 9 20th June 2010 11:18 PM
Cambridge Audio 640A V2 - service manual Paolo.n Solid State 0 7th July 2009 11:19 AM
Cambridge Audio Azur 640A toroidal power transformer (115V) limono Swap Meet 1 25th December 2008 04:57 PM
Copyright ©1999-2017 diyAudio
