Someone move this to Solid State please.
If the crackling is not volume dependent, the cause is likely to be near the input of the respective power amplifier, probably a bad solder joint or (less likely) bad transistor. Finding something like this can be a royal pain. You may want to consult an experienced repairman, who'd have an eye for soldering quality and could redo suspect joints quickly.
(Don't get me wrong, but if you're showing us a photo with not even the lid off, chances are you're not a repair wizard.)
- Chip Amps
- Kenwood KA-5090R T.R.A.I.T Stereo Amplifier Crackles
