Noob wanting to build chip amp, help appreciated
Old 29th June 2013, 08:05 PM   #41
Headbanger is offline Headbanger  Austria
Yes. You can use both of them to get 26-0-26, I guess that would make it about 35V rectified, with 8ohm speakers and proper heatsink it should be fine. One of my chipamps is running on +/-36V after active filtering and 6ohm speakers, but I do not recommend that.
Old 29th June 2013, 08:21 PM   #42
nubskillz is offline nubskillz  United States
I will be pushing 150watt/8ohm speakers. I will have to use them together to get the power I want.
I guess i will be regulating the supply since i will have the needed overhead with 27v secondaries.
Old 30th June 2013, 08:10 AM   #43
Connect the secondaries in series.
Leave the centre taps unconnected, but insulated.
You now have 26.5-0-26.5Vac at the mains voltage when you took your measurements.
If you do need an LV supply use one 13Vac and the series connection. That series connection is @ PSU Zero Volts.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 1st July 2013, 05:38 AM   #44
On the other hand, would running 1 trafo per chip at 13-0-13 be enough?
Old 1st July 2013, 08:48 AM   #45
look up the datasheet for your speakers and your chipamp.
regards Andrew T.
Noob wanting to build chip amp, help appreciatedHide this!Advertise here!
wanting to buy chip amp kit toller Chip Amps 7 29th October 2012 09:40 PM
Beginner wanting to build a subwoofer amp mk2singh Class D 8 28th October 2012 04:19 AM
wanting to build my own low powered amp. aidynphoenix Construction Tips 8 18th February 2011 04:49 AM
Wanting to build amp systemerror909 Pass Labs 13 2nd July 2008 07:13 AM
Newbie, wanting to build Amp PaulHilgeman Solid State 3 8th January 2003 02:24 AM
Copyright ©1999-2017 diyAudio
