Another heat sink size question - diyAudio
Old 23rd May 2013, 02:24 PM   #1
Default Another heat sink size question
Sorry for yet another heat sink question.
Initially I bought the larger heat sink for a LM4780 and the smaller one for LM3886TF.
As size comparison LM3886 and its board are included in the picture. The exact heat sink dimensions are:
Larger: 300x100x26mm
Smaller: 150x92x40mm
However, I wonder if I can get by with both chips on the larger heat sink? The heat sink is going to be mounted externally on top of the chassis.
Transformer voltage: 2x18V
Load for LM3886: 1x4Ω speaker
Load for LM4780: 2x4Ω speaker (in stereo mode)
Ambient temperature: Lets assume ~28-30˚C
Thanks.
Old 23rd May 2013, 02:32 PM   #2
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
You sure can!
Old 23rd May 2013, 02:57 PM   #3
KatieandDad's Avatar
The heatsink is best mounted so that the fins are orientated so that air freely circulates up the fins due to natural convection. With a huge heatsink that shouldn't be too much of an issue but I would "birds nest" run the amps on their heatsinks to see how warm they get before mounting everything into a case.
Old 23rd May 2013, 03:05 PM   #4
Thanks guys.
Note: the bigger heat sink has a shorter fin length.
By "birdnest" I assume you mean the fins on top and the flat side underneath?
I would really prefer a heat sink that has its fins oriented the other way. But since it would be obscenely tall if I mount it standing, the only other way would be to mount it "birdnest" style on top of the chassis.
Old 23rd May 2013, 03:21 PM   #5
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Originally Posted by Mihkus View Post
You sure can!
You sure can not !
A heatsink like that is efficient up to 100-150mm length max.
Beyond that length, it brings absolutely nothing to the table, expect in the order of 1.5 C/W at best. (need a reference ? )
Mounted flat on top of the case, thermal efficiency turns a lot worse.
Especially this one, due to few ribs, with only 4/5th of an inch rib height.
Raises the number to above 2C/W.
18V transformer => ~25V rails (assume 25C ambient, numbers will be worse for 30C )
LM3886 datasheet => 3C/W heatsink
LM4780 datasheet => < 1C/W heatsink (for 2 channels)
1/3 + 1/1 = 4/3 W/C => 0.75 C/W Heatsink !
It doesn't count how one deals with winning, but how to handle a loss (© DjT)
https://www.youtube.com/watch?v=FJEzEDMqXQQ
Old 23rd May 2013, 03:35 PM   #6
Vertical finned heatsinks are designed and specified for vertical fin orientation !!!!!!!
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd May 2013, 03:36 PM   #7
26mm is more than an inch?
And would that calculation stands with more than 1 heat sources? If the heat sink has a rating of 2˚C/W with heat radiating from a single point, surely the rating can not be the same with the same amount of heat radiating from opposite ends especially with such a long dimension (you said efficiency tops at 100-150mm)?
Old 23rd May 2013, 03:46 PM   #8
Originally Posted by Navyblue View Post
Thanks guys.
Birdnest means just connect it up as a mass of wires and see how it works best.
Old 23rd May 2013, 03:47 PM   #9
Andrew, I phrased my post to try and prevent confusion. Vertical fins can be read as lying on its back. The fins need to be, as the OP suggested, in the obscenely high orientation.
Old 23rd May 2013, 03:51 PM   #10
When the fins are pointing up, does it count as "vertical fin orientation"?
Heat-sink size 101 thor61 The diyAudio Store 5 28th October 2012 12:12 AM
Heat Sink Heat Sink Sources for Pass Amplifiers manmohan singh Pass Labs 9 16th March 2012 11:37 PM
Heat sink size, Need help in determining. marchel Solid State 32 8th August 2011 09:51 PM
Heat Sink tap/thread size wicked1 Pass Labs 5 24th August 2009 02:52 PM
heat sink size, easy calculation. space2000 Pass Labs 4 8th July 2008 02:34 PM
Copyright ©1999-2017 diyAudio
