how to unmute LM3886 ?
Old 22nd May 2013, 07:25 PM   #11
navZ is offline navZ
navZ's Avatar
Originally Posted by overall feedback View Post
I have no experience with LM3886 but looks like Rm current is too small for +-18V and 5k value. Check GND (pin 7) as well as power supply pins.
i have made more complex amps using tda7386, tda7294 perfectly working in once
and am not sure i am doing this ic correct. HOW FUNNY is that!
Moreover as i mentioned, i checked the current using multimeter in series from Rm to -V. At 5K it showed 0.99mA, but still no sound. At 1.5k, 1.4mA current was read, still the same.
Little worried if these are fake/damaged. But both ics showing same behaviour, i.e., at pin8 open, a little sound at full signal input whereas as soon its connected to -V via. 1.5K/5K/10K/22K, the little sound stops coming.
Here is the exact schematics I built.
Old 22nd May 2013, 07:56 PM   #12
Michael Bean is offline Michael Bean  United States
Michael Bean's Avatar
Does the non-inverting input have a dc-ground referance connection somehow? Schematic shows a single ground symbol which can't be right. There should be a separate ground path for: 1) input, feedback and pin 7 as a group, 2) power supply decoupling, and 3) speaker return and zobel. The power supply decoupling should be one small value ceramic disk (preferably COG/NPO) around 100nF with leads short as possible connected as close as possible to each supply pin and short path to common ground connection, and a medium size electrolytic (470uF to 1500uF) connected similarly with shortest possible leads.
Mike
Old 22nd May 2013, 08:28 PM   #13
navZ's Avatar
Mike
Oops, I had drawn so by mistake. Here is what i meant.
BTW, every diode is parallelly attached to 100nf. And i am quite sure this does not have any relation to the problem i am facing.
If i am missing something very important here, please at least draw me a rough sketch of modifications u recommend.
Old 22nd May 2013, 09:13 PM   #14
tauro0221 is offline tauro0221  United States
One thing that I noticed is that you are running both Lm3886 to the minimum permissible voltage allowed. I am running my at +/- 40 volts. I am not saying that running at +/- volts will not worked but it is a thought.
Old 22nd May 2013, 10:11 PM   #15
Mike
Old 22nd May 2013, 10:31 PM   #16
volume knob is offline volume knob  New Zealand
volume knob's Avatar
You need a resistor from pin 10 (Vin+) to ground
Old 23rd May 2013, 02:19 AM   #17
navZ's Avatar
I didn't get your point. please be specific.
Old 23rd May 2013, 02:24 AM   #18
navZ's Avatar
are you sure that its responsible for no sound, because I m feeding input via. 100k analog controller
Old 23rd May 2013, 03:19 AM   #19
Once again, does the non-inverting (+)input have a dc-ground referance connection somehow? If there isn't a DC path for the input bias currents to follow, no, it won't work.
Mike
Old 23rd May 2013, 05:15 AM   #20
overall feedback is offline overall feedback  Croatia
Maybe your input is attenuated, try with resistor to gnd and another source.
how to unmute LM3886 ?Hide this!Advertise here!
lm3886 help Bradford336 Chip Amps 20 17th February 2013 01:30 AM
Can't get TDA7266 to unmute fretless123 Chip Amps 1 18th October 2012 08:36 AM
Help my LM3886 Denis.BR Chip Amps 13 13th January 2012 06:45 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 10:24 AM
lm3886...i need help. Morbid Chip Amps 6 21st June 2004 09:18 PM
Copyright ©1999-2017 diyAudio
