how to unmute LM3886 ? - Page 3 - diyAudio
Old 23rd May 2013, 06:34 AM   #21
Alfonz is offline Alfonz  Bulgaria
Try another circuit! This is a good guide to p2p wiring(for example) or just try another working circuit from website.
And don't forget to post pictures of your progress!
Old 23rd May 2013, 07:31 AM   #22
Michael Bean's Avatar
No, do NOT build that Mick Feuerbacher thing! That is a prime example of an amp that is incomplete and prone to problems that could lead to much dissapointment, like ruined speakers. I always recommend reading and following the details in the data sheet paying close attention to the components on the schematic listed as "optional", they are not optional, except for very specific cases where it is known for sure how the amp will be used, otherwise all of those components should be included so the amp will be stable under all conditions.
Mike
Old 23rd May 2013, 10:26 AM   #23
AndrewT is online now AndrewT  Scotland
check your +ve supply voltage to Centre tap and -ve supply voltage to centre tap and -ve to +ve voltage.
check the voltage on pin 8 to centre tap.
Add a Zin resistor to allow the input offset current a route to escape. Otherwise you will cripple the opamp/chipamp if the input is DC blocked.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd May 2013, 08:45 PM   #24
Excuse me for posting that project Michael. Never tried it, but I've met some good feedback.
As for me I wouldn't try the author's circuit. May be a Zobel network will help.
Old 24th May 2013, 04:40 AM   #25
sangram is offline sangram  India
Originally Posted by overall feedback View Post
...try with resistor to gnd and another source.
Originally Posted by Michael Bean View Post
Once again, does the non-inverting (+)input have a dc-ground referance connection somehow? If there isn't a DC path for the input bias currents to follow, no, it won't work.
Originally Posted by volume knob View Post
You need a resistor from pin 10 (Vin+) to ground
This is why we want pictures, could have avoided all the nonsense over PM.
What is the DC reading on the output?
Old 24th May 2013, 09:44 AM   #26
San,
there are pics in posts 11 & 13.
regards Andrew T.
Old 30th May 2013, 10:01 AM   #27
navZ's Avatar
Mike
so are u saying if i feed input directly from headphone jack to pin 10, it wont work and i have to attach 1k series with 20k parallel to gnd for reference?
(...bcoz lately, i ve skipped 1k on input+).
Old 30th May 2013, 10:06 AM   #28
navZ's Avatar
18.1-0-18.6v dc, when not connected to ic.
and when connected, it drops around 0.6v on both rails.
Old 30th May 2013, 01:07 PM   #29
Yes, most (might as well assume all) opamp inputs (both the inverting and non-inverting) need a DC path to a low resistance node. A signal source may or may not provide that path for you, so you should include one yourself to be sure. The 1k resistor in series with the non-inverting input is usually there to limit current for reducing the turn-on and turn-off thumps and noises, so isn't really necessary for proper operation.
Mike
Old 30th May 2013, 02:50 PM   #30
San,
Sorry, should have been clearer - the OP has been on PMs with me for a month now and has stubbornly refused to every request to provide pictures and a schematic, even after me saying that it was not possible to remotely troubleshoot without a schematic.
It was once we saw the pics that things became clear to me
It wasn't possible to help him at one point without seeing this, and when I told him to open a thread, he assumed it was because I was being difficult, and even messaged me something about the tone. I chose to ignore that. I can't help those who will not help me help them :S
lm3886 help Bradford336 Chip Amps 20 17th February 2013 02:30 AM
Can't get TDA7266 to unmute fretless123 Chip Amps 1 18th October 2012 09:36 AM
Help my LM3886 Denis.BR Chip Amps 13 13th January 2012 07:45 PM
Are two separate lm3886 = 2*lm3886 in parallel or bridge mode rs1026 Chip Amps 11 21st October 2004 11:24 AM
lm3886...i need help. Morbid Chip Amps 6 21st June 2004 10:18 PM
Copyright 1999-2017 diyAudio
