Preamp with LM1036N and TDA7050
Old 20th May 2013, 01:43 PM   #1
cedric88 is offline cedric88  Belgium
Default Preamp with LM1036N and TDA7050
Hi all,
I'm currently building a preamp. The schematic is based on something I've found in an old dusty electronics book in the local library
It uses a LM1036N for vol/bass/treb/bal control and a TDA7050 as a headphone amplifier.
Based on the schematic I have made a PCB with Eagle. Inputs are selected on another pcb and Vsupply (12V and 5V) is also provided by another pcb using 7812 and 7805 regulators. The audio input signals will be connected via solder pens and shielded audio cable.
I've made a DIY amplifier a little while ago with PCB kits, and I've also made already some PCB's (not audio). However, this is the first time I've made an audio PCB and I'm not very sure if the ground plane I've drawn is good enough to avoid hum or noise. I've already read some stuff concerning ground loops.
Could any of you please take a look at the board to see if I haven't made any mistake or screwed some things up ?
Thx
Old 20th May 2013, 04:18 PM   #2
blu_glo is offline blu_glo  England
blu_glo's Avatar
My tuppence worth:
TDA7050: voltage gain = 27dB according to datasheet. From the headphone amps I've made, I've found such gains to be excessive from line level inputs. Typically I use 6dB and thats it! You do not need much to deafen yoursef even with high-impedance types! Attenuate the input to the headphone stage. Use low value resistors no more than a couple of K-ohms to keep noise to a minimum.
LM1036: Signal level handling - dependant on what you use, this device's max input of 1.6Vrms is a liitle on the low side. Most modern CD players will give out max signal = 2.2V rms. The older (?) LM1035 seems to have higher supply rail capability of 18VDC operating and as such comfortably
takes 3V rms input.
Old 20th May 2013, 07:28 PM   #3
Hi blu_glo, thanks for your reply and your advice !
I've put an attenuator before the potmeter. This should attenuate with -20 dB (please correct me if I'm wrong !)
Apparently I've also made a little mistake with the potmeter, the connections of the left and right channel were reversed
Here is a new improved schematic:
Click the image to open in full size.Click the image to open in full size.
Considering the signal level handling on the LM1036, would it be a good idea to also put an attenuator before the audio input of the LM1036 ?
Another concern I have is the ground plane. I haven't used a star in the grounding because that would have made the routing a lot more difficult. Is it a good idea to use a ground plane the way I did on a preamp PCB ?
Greetings
Cedric
EDIT: adjustment link to image
Old 20th May 2013, 07:52 PM   #4
blu_glo's Avatar
Your 20dB attenuator is about right, leaving you with 7dB of max headphone gain. This means you should at least be able to turn the headphone volume to a sensible position before deafening yourself!
LM1035/36 are interchangeable get your circuit running with the 1036 if you alread have it; then search out a 1035.... I wouldn't bother with the LM103x-attenuator complication, you'll loose signal/noise ratio (noise may get audibly worse)
http://www.datasheetcatalog.com/data...0/LM1035.shtml
Ground, hereafter referred to as 0V on line preamps is not quite as critical as you may be led to believe.
Input sockets->PCB input 0V [signal wire]
PCB output 0V-> supply 0V [supply wire]
PCB output 0V->ouput RCA 0Vs [signal wire]
Do not worry about using common 0V for left and right; channel seperation is already compromised within the IC and you won't hear the difference anyway.
Connect 0V supply to metal chassis somehere near input with 22-100R resistor and 0.1uF capacitor in parallel both component values non critical!
I'm assuming by "preamp" you do mean such and the power amps are in seperate enclosures elsewhere?
Last edited by blu_glo; 20th May 2013 at 08:13 PM. Reason: inserted LM1035/6 link!!!
Old 20th May 2013, 08:24 PM   #5
blu_glo's Avatar
looking at your PCB if it's not too late I'd put the input L and R input sockets 0V closer together (better still use 1 single wire) and ditto the L and R output ones closer together or same wire. Take power supply 0V input from close to the ouput sockets 0V.
Old 21st May 2013, 08:35 PM   #6
I've made a redesign of my pcb with your comments in mind. Inputs and outputs are now grouped. Output 0V is also close to power supply 0V.
This pcb will be in a separate metal enclosure. Power amplifiers will indeed be in a different metal housing. I will draw the power amps later, these will probably be based on LM3886's.
Concerning the LM1035, I've searched on Farnell, RS Components, Digikey and a couple smaller webstores but I haven't found anything ! Could it be that this LM1035 is out of production ?
Already thanks for your help !
Old 22nd May 2013, 05:10 AM   #7
blu_glo's Avatar
I beleive it has long since been discintinued however NOS may still be available....
Old 23rd May 2013, 11:20 AM   #8
I've found some of the LM1035's on the internet. I will order a couple of these but I will test the board first with the LM1036 since I have these already in my possession.
I will make and test the pcb this weekend, I'll keep you informed !
Cedric
Old 2nd June 2013, 07:39 PM   #9
Allright, so I etched and tested the pcb. At first everything seemed ok, I've tested it with a small power amp board I once bought as a kit (with TDA2050) and the sound is good.
However if I connect a headphone to it I've got a constant "hissss". This "hisss" sound is constant (doesn't change with volume higher). I can hear and manipulate the input sound with the volume pots but the "hisss" remains
Test setup can be seen in attachments.
Anybody got any recommendations what can cause this "hissing" sound ?
Cedric
Old 3rd June 2013, 05:25 AM   #10
blu_glo's Avatar
It's most likely the high gain of the headphone amp IC.
Quick questions (on my way to work!)
other than the hiss is the headphone circuit working?
is it quiet hiss in the background?
what position on the volume is loud but comfortable listening?
Is the outside of the POT earthed?
have you tried an earthed metal plate underneath the PCB?
Preamp with LM1036N and TDA7050Hide this!Advertise here!
LM1036N Potentiometer Type Hengy Analog Line Level 4 14th January 2013 09:20 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 05:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 06:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 10:57 PM
Lm1036n Leolabs Solid State 1 4th April 2005 03:17 AM
