Preamp with LM1036N and TDA7050
Old 3rd June 2013, 04:14 PM   #11
cedric88 is offline cedric88  Belgium
other than the hiss is the headphone circuit working?
Yes, the circuit works as it should
is it quiet hiss in the background?
Yep, the hiss remains constant whatever the position of the pot
what position on the volume is loud but comfortable listening?
I can open the pot completely without hearing distortion or ruining my ears (sound is not too loud I mean with that)
Is the outside of the POT earthed?
The outside of the pot is connected with the ground plane of the pcb. You can see this at the pic of the PCB I've posted earlier. However, my pcb is NOT connected to the ground in the test setup.
have you tried an earthed metal plate underneath the PCB?
No, I haven't. Could you explain this a bit more ? Is the earthed metal plate for shielding ?
Again, thanks for your help and quick reply
Greetings
Cedric
Old 10th June 2013, 07:41 AM   #12
blu_glo is offline blu_glo  England
blu_glo's Avatar
[LEFT]Yes, the circuit works as it should
Good. So fundamentally it's working!
[LEFT]Yep, the hiss remains constant whatever the position of the pot
So that's going to be noise from the TDA7050 which is a high gain chip. Not necessarily the best option for a headphone amplifier.....
Don't forget the LM1035 volume will also affect the signal and possibly noise passed on to this chip! try with LM1035 VOL pot set to max, then halfway and note differences (if any).
OK. What value is the POT? Couldn't see it in your schematic. I might suggest 10K and not much more. Also a 100pF from each chip input to earth.
Yes, shielding does help a lot especially where high gains are involved.
Not a problem glad to be of assistance.
Greetings
Cedric
Old 10th June 2013, 11:36 AM   #13
blu_glo's Avatar
Me: - OK. What value is the POT? Couldn't see it in your schematic. I might suggest 10K and not much more. Also a 100pF from each chip input to earth.
Sorry picked it out of the original, I assume you left it 22K which is not bad at all.... use ~100pf caps as previously mentioned on input pins.....
Old 21st November 2015, 12:13 PM   #14
blu_glo's Avatar
How did this project go?
Preamp with LM1036N and TDA7050Hide this!Advertise here!
LM1036N Potentiometer Type Hengy Analog Line Level 4 14th January 2013 08:20 PM
Tube Preamp Popping on Source Input Change (?) / 6DJ8 Preamp On Chip Amps Travis Clarke Tubes / Valves 3 16th October 2008 04:52 AM
Guitar Preamp = MIC Preamp = other preamp ,,are they all same? Paswa Instruments and Amps 1 12th March 2008 05:16 PM
twisted pear Preamp/other suggestions for Preamp kit LukeDuke Chip Amps 1 1st February 2008 09:57 PM
Lm1036n Leolabs Solid State 1 4th April 2005 02:17 AM
