8 Ohm LF driver for M-Audio BX5a Amp??? - diyAudio
Old 18th May 2013, 11:09 PM   #1
Default 8 Ohm LF driver for M-Audio BX5a Amp???
Greeting
I have a pair of M-Audio BX5a speakers, one of the LF driver is fried so now I am thinking if I can upgrade to an 8 ohms driver.
The speakers is an active 2 way with 30watts for the 6 ohm tweeter and 40watts into 4 ohm mid bass driver.
Thks
Old 19th May 2013, 03:55 AM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Why do you think going to 8 ohms is an "upgrade"?
You will cut LF power by half
Since it's a Studio monitor and accuracy is most important, I'd first try to get an original replacement from Manufacturer, and if not possible, would search for an as-equal-as-possible replacement and replace *both* at the same time.
These active cabinets are heavily equalized internally to get as flat as possible response; even fitting a "better" speaker there will not do, because compensation will be way off.
replacing Maudio BX5a amp need advice pantstain Chip Amps 10 3rd January 2013 11:01 PM
PA 100 voltage input if its 4 ohm driver / 8 ohm driver rhythmsandy Chip Amps 3 16th August 2012 12:41 PM
Ohm C2's with replacement LF Drivers... mpr2000 Multi-Way 2 17th May 2012 01:26 AM
M-AUDIO BX5a monitors : Tweeters out of phase ? jives11 Multi-Way 7 23rd September 2011 11:25 AM
B&C PE21 8" LF Driver ANDYLASER Swap Meet 3 15th July 2010 07:03 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
