Tda 2003 sound quality.Show me your opinion! - Page 2 - diyAudio
Old 22nd May 2013, 08:04 PM   #11
PetruV is offline PetruV  Romania
Originally Posted by ivanlukic View Post
Yes. They cost 3 euro each from Kelco in Belgrade, name of the kit is RK2003.
Theyre pretty cheap,ours are more expensive,also you need more filtering caps
Just a kid who likes building and modding things.No inspirational quote here for you
Old 2nd June 2013, 09:06 AM   #12
Now Post some images,guys,and maybe some opinions and recomandations
Old 8th June 2013, 04:12 PM   #13
Guys, i need help,my tda2003 amp makes a distorsion sound at loud volumes on one channel,but if i unplug it,for the 15 sec it runs on the smoothing capacitor,it sounds clean ,it triggers into this state at loud volumes,and can be reset by powering off,I need some help.Could it be because over temperature.It sounds as if its clipping with the bass,but like its only on one chanell and the clipping can be heard if i turn the amp down.
Could it be short circuit protection?it did this on an 150ma charger,but now i ugraded to a 4amp supply and still does this.
Please help me,the chip involved in the broken channel is a tda2003av,the other channel is a possibly fake[?] utc2003,but its not causing the problem
Thanks in advance ;D
Old 9th June 2013, 05:33 PM   #14
dannyjmf's Avatar
do you have the photo of your current TDA2003 amplifier ... post it over (make sure to take the picture top and bottom part of the PCB) ... and also the exact schematic you were using as well ... maybe i can help ...
The Names of the IC might not be a fake ... it is maybe from a different manufacturer uses different prefixes for it ... so many times i encounter for different types of ICs and transistor but end up doing the job it suppose to do with no problems at all ...
Old 9th June 2013, 07:54 PM   #15
Thanks,but it was just a wire being loose and tremblling with the bass,which probably reconects because of vibrations on switch off.Thanks anyways for the last line.
If you can post your pictrures of your tda2003 builds
Old 10th June 2013, 03:40 AM   #16
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
how to do a screen shot
I dont have pics of the amp itself but what i did...
I needed superbly slick and thin amplifier that fitted inside case that was 23mm x 120 x 185mm
I made it almost 2 years ago or so, the design of the board is horrible.
It had PCB2706 DAC and digital volume control, switching power supply (modified laptop charger)
Old 10th June 2013, 07:45 PM   #17
What kind of modifications did you do to the smps to be better,and in which way?
Old 11th June 2013, 10:07 AM   #18
Mihkus's Avatar
Just rewound output transformer primary.
Less wounds to get a bit over 14 volts bigger filter to get sqw clean.
I built pair of OB fullrange speakers with FR10-4 from visaton
The DAC and volume control were powered by USB 5V
DAC had serious problems with noise until i replaced most of the caps that were probably fake elna ****... nasty stuff from ebay may cause illnesses
I was gift for my mom...
Old 11th June 2013, 08:47 PM   #19
I did that to a normal line voltage transformer,i removed windings from secondary ,it a ads a lot of power to my tda2003 amp,but it kinda buzzes and gets hot,even when idling,but it seems as the winding stay cold but the core EI gets hot.I would need some help regarding the max recomanded temperatire for a transformer,line frequency is 50hz.
Thanks for the answers!
Old 12th June 2013, 02:15 AM   #20
dannyjmf's Avatar
how loud was the transformer buzzing then ....?? if it just a faint buzzing close enough to the transformer to hear it then it is normal
Quality Control differences = variations in sound quality? KT Class D 3 4th June 2014 12:02 AM
fake tda dac quality... smithie Digital Source 4 2nd November 2008 09:38 AM
TDA 7296A - any higher quality replacement? trodas Parts 0 18th July 2008 10:15 AM
TDA 1541A S1 special quality Bernhard Swap Meet 0 25th March 2007 09:49 PM
Show of hands for the Montreal Sound and Image Show (Le Festival Son & Image) alvaius Everything Else 2 28th January 2003 05:48 PM
Copyright 1999-2017 diyAudio
