"Bloated" sound from GC? - Page 6 - diyAudio
Old 20th May 2013, 05:37 PM   #51
iggy111 is offline iggy111  Croatia
I'm doing the changes now according to post#40, and some other things I was postponing. It will take some time so I will post again tomorrow after a listening test.
If all the patients survive, that is
Old 20th May 2013, 05:41 PM   #52
Originally Posted by minifly View Post
Would it be possible to connect Cc to gnd instead of -IN? Then it will work properly as an RF filter.
Yes, that cap will go from IN+ to GND. I'll just have to see if it fits across to pin7 (gnd) because I will solder the HF decoupling ground to pin7, so it could be crowded.
Old 20th May 2013, 11:09 PM   #53
The Rf cap goes to Signal Ground. Do not connect it to pin7.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 22nd May 2013, 05:28 PM   #54
Well, the patient didn't survive...
I opened a new thread to get to the bottom of the problem, link here
PS Andrew, I didn't do a ground lift to separate signal ground from power ground, that's why I meant to solder it to pin7. Should I do that?
Old 22nd May 2013, 05:37 PM   #55
Think about what you are proposing.
You are adding an RF attenuation to the Hot/Signal input.
Where is that coming from?
I reckon it is coming from the input cable. That cable connection is a two wire connection.
If you need to attenuate RF on that two wire connection then the Capacitor MUST go across Hot?signal to Cold/Return. Not to power ground.
If you are concerned about common mode interference, then both wires in the two wire connection must be cap connected to Chassis. Not to Power Ground.
regards Andrew T.
Old 23rd May 2013, 12:24 PM   #56
Check. And again, I shouldn't post when I'm tired
I guess the optimal place for that RF cap is across IN and SG (return) on the PCB underside.
Will do that as soon as I solder in a new chip, as one of them died.
As far as my initial problem goes - the healthy right channel seems not to be "bloated" any more, but more on that soon...
What makes an amplifier "bright", "warm", or "neutral"? JohnS Solid State 51 13th December 2009 07:42 PM
How to get "Radio Sound" on the GC vinnyvintage Chip Amps 9 7th May 2008 12:55 AM
How to get rid of "CKK" Sound on "turn off" riotubes Parts 0 25th November 2006 04:50 PM
LM3886 GC - "Simplest Ever Amplifier Bridging" jweber Chip Amps 20 18th June 2006 03:55 AM
GC "hybrid" supply Khron Chip Amps 19 15th March 2006 05:47 PM
Copyright 1999-2017 diyAudio
