Reducing the gain with an inverting gainclone - diyAudio
Old 30th November 2003, 08:26 PM   #1
Bricolo is offline Bricolo  France
Bricolo's Avatar
Default Reducing the gain with an inverting gainclone
I'm using Peter Daniel's IGC schematic, with the 10k input resistor and the 220k feedback resistor.
But when I use it with my CD player (Marantz CD62), I don't even turn the volume pot more than 5%. 10% is real loud. (I've got 92dB/w/m speakers)
Could I simply lower the gain by increasing the input resistance's value?
I think that could be a good think, since it would also result to a higher input impedance.
Is there no problem in doing it?
Old 30th November 2003, 08:30 PM   #2
Pedja is offline Pedja  Serbia
Bricolo, what's the volume control you are using?
Pedja
Old 30th November 2003, 08:38 PM   #3
Peter Daniel's Avatar
Send a message via AIM to Peter Daniel
Is it log, linear and what value?
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 30th November 2003, 08:46 PM   #4
Bricolo's Avatar
It's a cheap Pihier stareo linear 50k pot.
Do you think a log would give me more sensitivity at low volumes?
In fact, I think it's true. But lowering the gain, and this way, rising the input impedance, looked nice to me.
But I can do both...
Old 30th November 2003, 08:56 PM   #5
I found that 50k log pot works much better than linear pot and gives better control over the usable range.
If you really insist on using linear pot in this application, the value should be higher (at least 100k) although I'm not sure it would give as good control range (as log pot).
I wouldn't lower the amp's gain, as supposedly, GC works better with higher gain.
www.audiosector.com
Old 30th November 2003, 09:06 PM   #6
Bricolo's Avatar
I'll change it.
I already wanted to do this, since the two channels aren't very well matched at low volume
Old 30th November 2003, 09:53 PM   #7
Then yes, a logarithmic pot will solve the problem. That 10% of the linear pot will appear as the center position of the logarithmic one. Bad channel tracking you mentioned is the feature of all Piher pots which is a pity since these pots sound pretty dynamical (though not as clean and open as, say, ALPS, but the difference in cost is obvious). You should be really lucky to get the Piher with good channel tracking (or you should try at least a couple of them).
Pedja
Old 30th November 2003, 09:59 PM   #8
Bricolo's Avatar
Pedja
I've got a 100K log stereo Pihier with a good channel tracking.
But 100K could be too much for a gainclone.
I could also go the the local store with my dmm and ask to test a few 50K ones, the guy will certainly be ok
Old 30th November 2003, 10:31 PM   #9
The 100k log will be fine considering the attenuating curve. However, the total gain with thus formed feedback will be likely too low - I liked better the sound of 50k pot with 220k/10k feedback network. The best for you - try both, especially because you already have one and you have a possibility to measure before you buy. Btw be careful (nothing special, a bit of care will be enough), Piher is fragile and might not be happy because of too many/long soldering and/or too hot soldering iron.
Pedja
Old 1st December 2003, 09:05 AM   #10
Nuuk is offline Nuuk  United Kingdom
Nuuk's Avatar
...or build the stepped attenuator described on my Gainclone FAQ page which is designed for the IGC.
Cost is about 15-20 euros depending on what type of resiistors you use.
The truth need not be veiled, for it veils itself from the eyes of the ignorant.
Reducing gain on Bride of Zen? Yochim Pass Labs 20 15th November 2015 09:56 PM
reducing system gain slr 5000 Solid State 28 30th August 2008 11:05 AM
Reducing preamp/amp voltage gain? Stubb Solid State 1 1st November 2004 09:35 PM
Reducing gain on a minimalist OPA541 gainclone Alcaid Chip Amps 25 12th March 2004 07:55 PM
Gain of inverting amp BlairHatcher Chip Amps 16 1st August 2003 09:42 PM
Copyright ©1999-2017 diyAudio
