My_Ref Fremen Edition - Build thread and tutorial - Page 43 - diyAudio
Old 21st June 2013, 03:21 PM   #421
voxxonline's Avatar
Send a message via Skype™ to voxxonline
Ok
How to find time to finish my projects ?
Old 22nd June 2013, 08:17 PM   #422
fromthecrowd's Avatar
Default Additional headphone output
Is it permitted/acceptable to add a headphone output to My_Ref FE? Something like the one on the attached sheme. Note that the Out_Gnd lines of right and left blocks have to be joined for this. Comments highly appreciated!
Old 22nd June 2013, 08:27 PM   #423
voxxonline's Avatar
I don't know the answer, but may I ask how is the sound ?
Old 22nd June 2013, 09:14 PM   #424
The amplifier is not assembled yet, so its early to make objective judgements. But, ofcourse I listened to it a lot in its scattered state and with cheap pots and with preliminary wiring. Computer with O-DAC was mainly used as a source. May be the O-DAC is not top of the class, but it certainly is far better than FM tuner. Music was Mozart violin and piano concertos, Terauchi electric guitar, Weber rock opera JC Superstar. First of all bass on the speakers had to be lowered (they feature regulated crossover). Because the bass is very strongly expressed. After that the sound became pleasant and detailed. It has the property of being not fatiguing on a long term. I heard these AR10pi speakers driven by a couple of my fathers Marantz amps (the 80s models, don't remember which) and lately by a LM1875 chipamp (not bad). Compared to those My_Ref FE is distinctly better. Music appears well balanced and articulated. That is, instruments are not obscured one by the other. Merely by refocusing attention one can distinguish the particular line. The challenging string instruments are very authentic. I look forward to examine the sound of egyptian horns in the Aida with this amplifier. Never heard them properly reproduced. These are my impressions for the moment. A lot more listening is planned and I will continue to share my impressions.
Old 22nd June 2013, 09:55 PM   #425
Reality first!
ClaveFremen's Avatar
Sorry, I don't know...
Interesting...
If this is a problem it can be addressed changing C13.
A NOS K71-4 (which is a bit bass shy but really refined) may bettter suit you needs.
The MP915s on the regulator have a big role in bass response, you can swap them with metalfilm resistors to lower it if C13 swap it's not enough.
Thanks for sharing, I'll read with interest next posts.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - My_Ref Fremen Edition Group Buy 10th Run.
Old 22nd June 2013, 10:35 PM   #426
Dario, thanks for valuable advice! Plans are to mount the scattered parts to an open chassis, and after that to start tuning. Regarding the bass issue, old AR speakers may be responsible for that. Large drivers had torn rubber replaced few years ago. And, the drivers being not one of the standard sizes, the repair went not without compromises. They may reproduce deep bass not very well (for instance, contrabass in Mozart's 3rd violin concerto). At the lower bass settings of crossover they work nicely with My_Ref now. Also the source may not have been perfect. I will listen for some time and try variants of C13.
Old 23rd June 2013, 12:56 AM   #427
lehmanhill's Avatar
I'm sorry to say that, just like Dario, I don't know the answer. I suspect that you might give up some sound quality or hum on the headphone side because you may be introducing a potential ground loop by combining the grounds. If you keep the switches and headphone components close to the audio ground from your source, it might be OK.
I don't think you would hurt the amps by trying it. Why not just try it as an experiment before building the enclosure? We would love to hear about it.
Old 23rd June 2013, 01:15 AM   #428
bcmbob is offline bcmbob  United States
I had several AR speakers "back in the day" and they were all acoustic suspension. I'm assuming if yours are some of those great classics - yours are also. Though considered the "Cadillac" of sound production by many, as I remember their best reviews had to do with clarity over coloration. The last few speakers I've built are all bass reflex, as driver technology for controlling cone movement has really improved. My preference has kept me there and I'm not claiming it to be a top choice for everyone.
I'm simply suggesting if you don't own any, try to find a pair of good quality BRs somewhere in your auditions. I suspect much of the mid warmth the FEs are capable of might be masked by the "clean" nature of acoustic suspension cabinets. Just Sayin.....
Bob M.
"Arrange Whatever Pieces Come Your Way."
Old 23rd June 2013, 05:32 AM   #429
Yes, I'll do it in the coming week and report. Thank you.
I appreciate and will follow your advice.
Old 23rd June 2013, 03:00 PM   #430
voxxonline's Avatar
Allright.
I have tested one channel.
It is only one speaker but simple thing- soundstage from monophonic sound was already promising.
All and every detail of the music qualitative evaluation was 10 light years ahead of the amp I have now.
Will wait for another board to be done and will give my impressions then.
I can imagine break in of all parts is going to take place so sound should get better after that also.
Bass is good. 3D sound and separation of instruments great.
The only thing - I must be liking more rolled off high end than I have now- but it is the domain of k71-4 cap in b1 (together with nichicon electrolytic which adds some highs on top). Because I am changing to another passive pre with buffered dac - things will improve.
Plus, again- break in...
And yes- this amp is unforgiving to bad mastering and SQ.
Sincerely yours
Ivan
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 07:21 PM
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 12:16 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 10:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
Copyright 1999-2017 diyAudio
