My_Ref Fremen Edition - Build thread and tutorial
Old 2nd May 2018, 01:29 AM   #3891
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Welcome! It is a great community with people from beginners to experts and many willing to help. At 92 and 90 dB sensitivity, the two speakers you mentioned should have no trouble at all.
One other question, what do you plan for a pre-amp or just volume control? At 90 dB sensitivity or higher, you could just use a stereo potentiometer for volume control.
Jac
Old 3rd May 2018, 09:19 AM   #3892
Cowmans is offline Cowmans  Belgium
Jac
I'll start with a stero potentiometer, maybe later I'll add a pre-amp. Step-by-step
Old 5th May 2018, 04:22 PM   #3893
Telstar is offline Telstar  Italy
There is no need of an active preamp with this amp or any high-gain amp for the matter. You can achieve higher performance (i.e. transparency) with high quality attenuators and transformers.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 13th May 2018, 03:28 PM   #3894
murgui is offline murgui
Hello guys, after a few weeks seeing the nice projects performed in this forum I decided to start to build my first amp with the MyRef FE. I got the schematics (v1.7) from the drive and I'm trying to understand every circuit's component. In the Original MyRef there was a technical document explaining most of the building blocks, but I haven't been able to find in MyRef FE, and there are some differences from the original design. I think that going through hundred of pages of the post is far from optimized. So, is there any document like that?
Old 14th May 2018, 09:27 PM   #3895
UnixMan is offline UnixMan  Italy
UnixMan's Avatar
AFAIK there isn't any specific document like that... but conceptually there are basically no differences. There are only a few improvements, mostly inspired by Mauro's "My Evolution" amplifier.
The main difference are:
1) the power supply for the first stage, which on the original MyRef was just a simple resistor+Zener while on the FE there is a CCS + a more elaborated shunt regulator (see the PSU block on the top-left of the FE schematic);
2) the internal limiter network (those Zeners between the first stage and the current pump), for better clipping control.
Another (obvious) difference WRT to the original MyRef (but not WRT some other implementation, such as the one by TP) is the full "dual-mono" configuration of the FE (the original MyRef was configured as a stereo amp on a single board, with some ancillary parts in common for both channels).
There are also some minor differences in the compensation networks.
"We should no more let numbers define audio quality than we would let chemical analysis be the arbiter of fine wines." N.P.
Old 21st May 2018, 04:54 PM   #3896
You are right, thanks!
Old 27th May 2018, 03:54 PM   #3897
Ö In the Original MyRef there was a technical document explaining most of the building blocks, Ö Regards,
Hello Murgui, where dit you find this document for the original MyRef?
Thanks.
Old 3rd June 2018, 05:46 PM   #3898
Hi, you can find the document in the original post by mauro penasa. Or here PROGETTO“MY_REF”
Also, I’ve been struggling to find what’s the goal of C10, can anybody tell what’s it goal?
Nicolas.
Old 5th June 2018, 06:52 PM   #3899
Hello guys, can you please explain what is the goal of C10?
Old 5th June 2018, 06:54 PM   #3900
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Default My_Ref Fremen Edition - Build thread and tutorial
Itís part of the compensation scheme.
Dario
ClaveFremen "Bailando Salsa en el Sietch" - For My_Ref FE 12th GB extra boards PM me.
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 03:03 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 06:21 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 09:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
