My_Ref Fremen Edition - Build thread and tutorial
Old 18th September 2017, 07:27 AM   #3481
Originally Posted by Joseph K View Post
I mean: raising the value of R3 lowers the gm, the conversion factor of the current pump. So it brings more stabilty ( less loop gain)
So it is a change which brings .more stability, at the price of less performance and more circuit losses. If Mauro had decided to use less of it, he considered worthwile - why should we explore backwards..
The current pump relies on accurate matching of the ratios R8:R9 to R5:R6
R3 is the change made for the improved current pump. This now requires R9:{R3+R8} to be ratio matched.
R3's precise value is not critical to the proper operation of the current pump.
http://www.ti.com/lit/an/snoa474a/snoa474a.pdf
Note the 1% tolerance for R13 in figure 6.
I wonder if the slight change in R3 resulted in a more accurate ratio match?
Could that have given rise to the apparent improvement?
I have shown recently, the evolution of the distortion performance at different stages of the design.
The clear visible step between classic and rev-A compensation is in a nice part due to the R3 changed.
For stabilty it is probably less critical. Did not do a deep investigation. Don't see a reason for it..
Ciao, George
regards Andrew T.
Old 18th September 2017, 07:35 AM   #3482
Joseph K is online now Joseph K  Hungary
Andrew,
I have been explaining in the wider context, with the current pump and it's amplification factor as part of the composite amplifier. R3 is the single most important part in defining the current pump's transconductance.
Then this transconductance is working on the actual load impedance.
By changing R3 one changes the open loop gain.
Ciao, George
Old 18th September 2017, 09:16 PM   #3483
atupi is offline atupi  Romania
Thanks for all replies, very useful! I was trying to understand if I really need to order 0.33ohm resistors or is ok to keep old 0.47ohm ones in order to have Rev A Evo mods
Rega RP-1/Simplistic RIAA by Salas/ DCB1 clone/ MyRef Fremen Edition/FC-100/ XTZ 99.26 MkII speakers
Old 18th September 2017, 11:24 PM   #3484
soongsc is offline soongsc  Taiwan
soongsc's Avatar
In my experience increasing current gain did provide a more clean uncolored sound. I think i also posted some damping measurements in the original Myref thread.
Hear the real thing!
Old Yesterday, 12:30 AM   #3485
In fact, Mauro's revA mod and these recent successive modifications/ versions are all raising the current gain in the pump - with respect to the original, or standard configuration.
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 06:21 PM
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 11:16 AM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 09:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Copyright ©1999-2017 diyAudio
