My_Ref Fremen Edition - Build thread and tutorial
Old 20th April 2017, 02:08 PM   #3001
Dave S is offline Dave S  United Kingdom
Originally Posted by ClaveFremen View Post
Nice build
I suppose you like what you hear...
1st impression is that it sounds fast and tight, with clear separation of instruments. Excellent harmonic structure with brass etc. Maybe it's a touch lightweight, but that could be the toroids (used with several amps previously and tend to have this character), or maybe it needs to some use for the parts to settle down.
Actually this was quite a tricky build:
- the 1/4" terminals are rather close to the rectifier diodes and require sleeving and careful fitting
- access to a screw to fasten the 3886 is blocked by other components and it's not possible to use an ally bar to clamp it, for the same reason.
I will probably change it to R-cores and Rev A and a nice box if it become my favourite amp.
Just checking... for Rev A (changing from FE):
- change R3 from 0.5R to 0.33R
- delete C10 and R39
Is that right?
Old 20th April 2017, 02:12 PM   #3002
Bas Horneman is offline Bas Horneman  Netherlands
diyAudio Moderator Emeritus
Bas Horneman's Avatar
Hi Bas,
When I read post #2988, I think rgaudio is saying that it is quiet with shorted input, but makes white noise when he connects to a signal source. If I understand correctly, then he could also have a ground loop issue.
Jac
You are correct!
Old 21st April 2017, 12:26 AM   #3003
ClaveFremen is offline ClaveFremen  Italy
Reality first!
ClaveFremen's Avatar
Lightweight? Weird... did you observe suggested orientation for all parts?
Also input cabling could have a role, it seems you recicled pairs from an ethernet cable, isn't it?
VA rating of transformers?
Never had problems with faston tabs... they're a bit tight with 35mm caps, though.
The LM3886 should be fixed by a nut over a M3 grub screw:
My_Ref Fremen Edition - Build thread and tutorial-img_2760-jpg
My_Ref Fremen Edition - Build thread and tutorial-socket-screws-2_billboard-jpg
Rev A is an improvement, as r-cores if you can find them now that Selectronic is no longer in activity...
Is that right?
Correct
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 21st April 2017, 01:21 AM   #3004
lehmanhill is offline lehmanhill  United States
lehmanhill's Avatar
Hi Dave,
Like Dario, I'm a little surprised to hear lightweight. Of course, I out of touch using an older version, but I think the same things probably affect bass (Dario, please jump in and correct me). I see that you are already using the Mundorf power supply caps. That's good and was found to help the bass in early testing.
As Dario implies, with Toroids, a higher VA rating seemed to help bass as well. I've been using 300 VA Antek toroids, which is overkill, but a bigger VA is an option if you can't find R-core.
The other thing I noticed is that it appears you are running a DC coupled input (no input capacitor blocking DC). Normally, that cap and the input impedance resistor define the bass corner frequency of the bandwidth as well as affects the sound character a bit. When you are DC coupled, I'm not sure what defines the low end of the bandwidth, but I think the characteristics of the source device output impedance become part of the equation. I hope someone smarter can explain this phenomenon.
Anyway, I hope you enjoy it, I have.
Jac
Old 21st April 2017, 02:48 AM   #3005
Spartacus is offline Spartacus  United Kingdom
The low frequency bandwidth will be defined by the feedback cap C9.
I run without an input cap, and the low frequency weight is superb. I also use 300va torroids, but also some non standard mods which probably help.
i'd suggest to get used to it for a while, and let your (Dave's) amp/ears burn in.
Old 21st April 2017, 08:36 AM   #3006
The lightweight sound was not the amp!!!!
I don't need an input cap for a very good reason!
Here's what happened:
- after my usual bench tests to check stability and correct operation I put the amp in my system and took and posted the picture
- after 1/2 hour of listening Dario posted asking for my thoughts on the sound
- I made the schoolboy error of commenting immediately
- after further listening I realised something was really not right. I then looked againa the the schematic and realised the gain of the FE is significantly higher than my usual amp(s)
- I turned up the bass level on my active XO so that the <100Hz matches the main speakers - leanness instantly fixed!
Anyway, apologies for the false alarm. I will not be commenting again on SQ until the amp has clocked up some decent hours and I have done some proper comparisions.
Old 21st April 2017, 08:42 AM   #3007
Reality first!
Don't worry, the important thing is that you fixed the 'problem'
Keep us informed
Dario
Old 21st April 2017, 01:41 PM   #3008
lehmanhill's Avatar
A
Dave,
I'm sorry. I didn't mean to suggest that you need an input cap. I was just rambling on about things that were different from standard and possibilities that would affect bass.
And Spartacus is right about the low end cutoff frequency in a direct coupled FE amp. I knew that, but wasn't thinking clearly. I should think before typing next time.
Anyway, I'm glad you found the source of the issue. Enjoy your experiments.
Jac
Old 21st April 2017, 03:57 PM   #3009
Jac,
I also didn't mean to sound aggressive in my reply. Anyway I am confident to run without an input cap because:
1) The FE doesn't receive any signal at LF
2) I am confident my XO does not output dc (at least <2mV)
3) The DC protection will hopefully save the day if it's ever needed
Interim report (can't resist) after a few hours of listening:- Wow! This is a very, very good amp!
Old 21st April 2017, 04:11 PM   #3010
lehmanhill's Avatar
Dave,
You didn't sound too aggressive. I just wanted to make sure I wasn't sticking my nose in where it wasn't wanted. We're fine.
As for your interim report, Oh Yeah!
Jac
My_Ref Fremen Edition - Build thread and tutorialHide this!Advertise here!
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1526 8th October 2017 04:03 PM
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 07:21 PM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 04:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 10:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 02:04 PM
