My_Ref Fremen Edition - Build thread and tutorial - Page 12 - diyAudio
Old 5th May 2013, 04:50 PM   #111
lehmanhill's Avatar
BTW,
I took a quick look and it looks like the gain of the Audio Sector and the MyRef are about equal. Should work.
Old 5th May 2013, 04:52 PM   #112
Reality first!
ClaveFremen's Avatar
Originally Posted by SoIL4x4 View Post
Will do, I will try to get to it today, but I have a project deadline that is looming so it may be this week.
Fine.
P.s. I also built a Bob inspired volume control from leftovers that sounds great!
It's a TKD 2CP-601, isn't it?
From what I've read it should be way better than Alps Blue Velvet.
Dario
ClaveFremen "Bailando Salsa en el Sietch"
Old 5th May 2013, 05:13 PM   #113
No 4 is offline No 4  United States
Yes it is the TKD, and yes it is way better than the alps. I put one in my integrated build too. Very smooth and excellent channel balance.
Will.
Old 5th May 2013, 11:52 PM   #114
BTW is offline BTW
Thanks a lot, great info... Looking forward to building My-Ref ..
Originally Posted by lehmanhill View Post
BTW,
Old 9th May 2013, 02:45 PM   #115
I finally got a chance to break away and do some soldering last night. I connected the input next to the in ground and installed a jumper on board at c13. With source connected the and no pgnd I still have hum. With inputs shorted I have no hum in the right channel but a very small amount in the left. The left channel is the one that has the input pair that is close to the k71 on both sides. With pgnd connected though I get silence no hum or hiss in both channels. I am really begining to suspect the k71s and their location. I have thought about insulating the body of the caps because they are metal to see of that helps with noise, but really at this point I think I need to rewire. I know Dario has fit these caps on the board in one of his builds so I may pull everything apart and make those and a few other changes. I should be able to do that this weekend.
Will.
Old 9th May 2013, 07:05 PM   #116
Apart from hum levels, did the "small loop/C13 jumper" configuration sound different? It has been strongly suggested but not yet demonstrated that a smaller loop will yield perceptibly improved high frequency response. I doubt it will matter at all, but I am prepared to accept experimental results. I have used the C13 direct-to-board configuration (connected at the circuit side, not the input side of the C13 pads) for every MyRef build, yielding outstanding results with a moderately large loop. I think more solder joints and additional connectors, no matter how good, are more detrimental to sonics than a slightly larger loop.
It will be difficult to eliminate hum until you get input signal wiring away from power supply. Always strive to keep signal and mains as far apart as possible. Shielding or twisting wires is not as effective as physical space. This may be difficult with your current layout.
Pic is my first crude build, couple years ago. Still works perfectly, with no hum or noise. Note the input cap connects RCA directly to circuit side of C13pads. Input ground wire is completely separated.
Peace,
Tom E
Old 9th May 2013, 10:40 PM   #117
lehmanhill's Avatar
Will,
Like Tom, I am interested in hearing your thoughts on if there is a sound difference. It is a really interesting question you are playing with.
Tom,
Just curious, in the picture, how did you support the input cap in that build and how would you do it differently if you were mounting an off-board cap today? I see the cable tie, but can't see what is underneath.
Jac
Old 10th May 2013, 12:07 AM   #118
Surprised you could glean that much information from my crummy photography. The cap rests on (is almost encapsulated by) a thin piece of firm foam rubber which is, indeed, secured by a cable tie routed through two holes drilled in the floor of the enclosure. I still do it the same way, except now I use dense cotton soundproofing material (leftovers from lining my speaker enclosures) instead of foam to form the cap cradle. The black stuff inside the enclosure is Soundcoat damping material from Parts Connexion which is very effective on thin gauge (cheap) aluminum.
As you can see, I am not the least bit interested in attractiveness or even tidiness, but there is planning toward a goal: shorten signal paths and reduce vibration. No one will ever hear how pretty or ugly the insides of an amplifier are.
Peace,
Tom E
Old 10th May 2013, 02:24 AM   #119
Tom and Jac, interesting question about the difference in sound. I dont know if I am looking for a difference because the question was asked, or if it is really there, but here it is.....
I did not do much listening last night after I made the changes. I checked for hum hiss etc. reconnected pgnd listened for a few minutes and went on to somthing else. It sounded good, but I did not do any critical listening. Today I listened to a few of the usual subjects through the ESS monitors. As usual the sound is amazingly clear, perfect seperation, and great soundstage. The one thing that stood out tonight, while listening to Miles Davis, kind of blue, was the soundstage. Everything seemed the same, but the soundstage seemed different. Real or imagined the soundstage seemed to come from in between the speakers and beside them more than usual. More listening will tell the tale.
As for the wiring I noticed somthing about Toms build and some of the pictures Dario has sent me. Both builds utilize short wire runs, but niether build uses twisted pairs. In Toms build the cap is the signal hot, and the signal ground is not run parallel to the cap. Not quite a right angle, but probably close enough. Now in Darios build with the K71s the caps are on the board, but the signal ground is very close to the cap, but it does not run parallel to the cap like in my build. the ground intersects the cap at a right angle. The wire runs in my build are different for both channels but similar in some areas. The ground portion that runs in between each channel is the one place they are the same.
I would of course like to keep the caps where they are, but yes Tom the sound trumps all asthetics. I think before I abandon the current mounting system I will do some expiriments with the wiring. I will shorten the paths as much as possible, I am going to split the signal hot and the signal ground at the rca at a right angle. I will report any changes. Hopefully my mistakes and subsiquent attempts to repair these errors will be of use for future builders. Sorry if this comes off as a rambling, it has been a long week!
Will.
Old 10th May 2013, 08:05 AM   #120
The Signal Ground and the Signal Hot at the RCA,m MUST be kept VERY close.
I attach/solder the Return wire to the "end" of the barrel right next to where the Hot exists the barrel. I don't use the solder tab. The gap is probably less than 1mm and possibly <0.5mm. That is small loop area.
regards Andrew T.
Sent from my desktop computer using a keyboard
My_Ref Fremen Edition RC - Build thread ClaveFremen Chip Amps 1273 4th July 2016 06:21 PM
My_Ref Fremen Edition - Beta build/Fine tuning ClaveFremen Chip Amps 1523 1st December 2013 11:16 AM
My_Ref Fremen Edition - need help on PCB evaluation ClaveFremen Chip Amps 450 23rd October 2013 03:38 PM
My_Ref Fremen Edition Interest/Group Buy ClaveFremen Group Buys 348 25th June 2013 09:58 PM
Last My_Ref Fremen Edition RC boards for sale ClaveFremen Swap Meet 3 4th December 2012 01:04 PM
Copyright 1999-2017 diyAudio
