TDA 1006 datasheet
TDA 1006 datasheet
Old 28th November 2003, 09:17 AM   #1
palesha is offline palesha  India
Default TDA 1006 datasheet
I hv one hometheater from china having TDA1006 faulty. I am not able to get the datasheet of the same. Kindly help me in the matter. It is like TDA 2030.
MP
Old 28th November 2003, 09:40 AM   #2
Netlist is offline Netlist  Belgium
diyAudio Moderator Emeritus
Netlist's Avatar
Are you sure it's a TDA1006.
TDA1006 is not at all like TDA2030.
/Hugo
Old 28th November 2003, 10:03 AM   #3
That is what printed on IC. Further i found that many chinese mfg.'s r using the same IC. u can confirm on net. This same thing is puzzling me. Now i hv downloaded YD1006 datasheet.
MP
Old 28th November 2003, 10:46 AM   #4
Netlist's Avatar
TDA1006 is a motor speed controller IC.
TDA2030 and YD1006 are 18W power amplifiers.
/Hugo
Old 19th November 2007, 01:41 AM   #5
WEALSPEAKER is offline WEALSPEAKER  Libya
please tell me what i can replace for bad yd1006 ? is there any equivalent ic
Old 19th November 2007, 02:05 AM   #6
Paswa is offline Paswa  India
Paswa's Avatar
eqivalent of YD1006 is TDA2030 from ST, both r 18w audio amp.
Old 19th November 2007, 07:28 AM   #7
are you sure yd1006 equivalent to the tda2030 i mean regarding the pin configuration and the performance ??? i know they both 18 watt but can they be interchangeable if one another ?
Old 19th November 2007, 03:08 PM   #8
Paswa's Avatar
friend, please wait a while, I'll write u next day after final confirmation..
Old 20th November 2007, 08:18 PM   #9
pawsa your reply take more than expected any way thank you
the speaker is lying on the bench waiting for repair please forum members if any one can help me i have a speaker that has tda1006 burn can i replace it with tda2030 or they are not interchangeable
Old 21st November 2007, 03:11 PM   #10
Paswa's Avatar
ok ok, i was just a little busy 4 me exam.
1>YD1006 and TDA2030 are same in pin config. you can also check it in TDA2030 datasheet here
The YD1006 app config here, it is same to the TDA2030, pls check it again
TDA 1006 datasheetHide this!Advertise here!
6G-A4 anyone have a datasheet? jp74 Tubes / Valves 5 23rd June 2009 05:28 AM
Datasheet psu, 0.1v to 50v @1a... redrabbit Power Supplies 6 26th April 2006 01:32 AM
