Someone tryed this?
Someone tryed this?
Old 27th November 2003, 10:26 AM   #1
MaXiZ is offline MaXiZ  Italy
MaXiZ's Avatar
Send a message via ICQ to MaXiZ
Question Someone tryed this?
Click the image to open in full size.Some one tryed this?
I've build it.. PSU is a SMPS at +20@8,5A enough i think..
BUt when i connect the power amp the car stereo turn off and nevere turn on again once i disconnect the power amp...
I've thought that maybe the smps but without the power amp it's all ok.. And this happen when i connet the positive and gnd to power amp.. If i connect only the negative and gnd the stereo remain on but without any sound...
What's maybe wrong?
Old 27th November 2003, 02:42 PM   #2
GregGC is offline GregGC  Canada
Default Re: Someone tryed this?
What's maybe wrong?
On the amp SCH it sais +/-V. Are you using single voltage supply (0/+20V). If that's the case you really need a output cap. I don't think I understand well your setup.
Greg
Old 27th November 2003, 04:26 PM   #3
MaXiZ's Avatar
Exactly
Where should i put this?
I'm not an engeneer! Sorry!
Old 27th November 2003, 04:44 PM   #4
li_gangyi is offline li_gangyi  Singapore
li_gangyi's Avatar
he's asking if you use dual or single supplies...and if you have an output cap (or is considering one) and can you describe the whole setup u plan to use for us??
Kids in the back seat cause accidents...Accidents in the back seat cause kids...
Old 27th November 2003, 04:52 PM   #5
MaXiZ's Avatar
sorry!
I use ONE car battery that is directly connected to a car stereo, the SMPS is connected to it and give +/-20@8.5A with 4.400uF per rail.
At the moment for a test i would use this setup..
Car stereo=>Power Amp (tda1514)=>Speaker
Old 27th November 2003, 05:17 PM   #6
sorry!
Just finished drawing that. and then I red your answer. So forget about my crappy art.
It is a gnd problem I think. Is the GND (-) of the battery connected to the gnd of the SMPS power supplay, or they have no internal connection?
The IC pack is connected internaly to -V. Where did you mount the IC. Is it mounted on heatsink touching the gnd. I suspect something to do with that (since I cant see the actual setup).
Old 27th November 2003, 05:29 PM   #7
MaXiZ's Avatar
This mean that i mustn't take ur schematic?
naturally yes! Why?
What does this mean?
I've looke and don't seems to me...
Do u mean how the component are mounted?
Old 27th November 2003, 06:20 PM   #8
MaXiZ's Avatar
and i've noticed another thing...
i've made a test to see if there's a gnd problem as u say..
If IC is connected seems like + & - are directly connected, instead without it like there's a 2000K resistor...
Contact me privatly too.. if u can..
icq:47573544
mail:maxiz@inwind.it
Old 27th November 2003, 11:36 PM   #9
Lars Clausen is offline Lars Clausen  Denmark
If you are going to use a chip amp like TDA1514 you might as well buy it here: http://www.elmatrd.ro/amplificatoare.html
the price is the lowest ever seen.
1000000 Romanian Lei is equal to 29 US$
Old 28th November 2003, 02:24 AM   #10
JojoD818 is offline JojoD818  Philippines
JojoD818's Avatar
Someone tryed this?
Maxiz,
Are you sure you checked your connections? If you made a pcb, please try to check your paths. Remember, if an amp is designed to be fed with split supplies, NEVER connect only one rail at a time.
Is a non-smps supply available, a lower voltage maybe? this can help in trouble shooting alot.
JojoD
Someone tryed this?Hide this!Advertise here!
any 1 eva tryed using 'phones + sub for infra? Helix Everything Else 5 7th July 2011 11:13 PM
Did someone tryed this? MaXiZ Solid State 13 22nd April 2005 12:06 PM
I tryed reply on a email from Vuamp2 sonnya Everything Else 1 15th January 2002 03:51 AM
Copyright ©1999-2017 diyAudio
