What the heck?  It's less than lunch!
Old 4th April 2013, 08:05 PM   #61
xrk971 is offline xrk971  United States
xrk971's Avatar
Originally Posted by radiosmuck View Post
Jeez, I had no idea of what you had achieved until I took delivery of my ready made tpa3123 board. Was this just a one off challenge or do you intend to build other tpa31xx amps?
The dead bug looks more like a cancerous growth, I mean that in a nice way
I'm appreciating the sound of this amp, perhaps more than the ta2020 whch I have several of. I cannot see there being any difference in sound quality between the tpa31xx amps?
I just need to chase down some faceplate lamps before putting my old McIntosh ss amp on Craigslist, I'm a d-amp convert.
Hey thanks for the kind words - cancer is a good way to describe it Glad to see we have another class D convert! The dead bug was a one-off challenge to myself to see if I could "McGyver" an SMD amp from parts and nothing more than SMD "fleas", paper, glue, and wire. Indeed it works but thinking back how painstaking the wire-bonding process was to get those 0.6 mm pitch pins soldered and leads to go out to usable wires I am not sure I would do it again. Especially after building the TPA3116D2 using a PCB - boy that was like child's play to solder SMD components to the fat nicely tinned solder pads after working with the dead bug style.
So I have built both the 3118 and 3116, and really, they sound very much alike - wonderful, dynamic, and superb resolution/clarity and definition. The 3116 goes a little louder (50 watts max) but not sure if it is that big a deal. The 3118 has an advantage of being able to select a modulation at up to 1.2 MHz whereas the 3116 is only 600 kHz max. The use of extra capacitors on the power supply pins makes a big difference in the bass.
The next ones I build I will design my own PCB using Eagle, then send the Gerber files off to China for cheap boards (Itead does 10 for $10 double-sided as long as it is under 2 in x 3 in). Have not used Eagle yet but looking at demo teaching vids on YouTube it doesn't look too hard.
If I dead bug again, it will be to make an active cross-over/pre-amp for my two TPA amps so I can bi-amp a FAST system without any passive speaker level x-overs. I have located a nice ultra-low distortion audio quad op-amp from TI for this. Just need to get some resistors, bypass caps, pots, and I am good to go...
Although, when I did the dead bug, I did not have the proper smallest soldering iron tip available - I was using an 0.035 in vs 0.015 in. I also had fat 0.035 in solder instead of the 0.015 in solder. That may make a difference in ease of wire bonding.
Old 6th April 2013, 12:00 PM   #62
Mark2727 is offline Mark2727  United States
Default $6 amp - impressions after about a week
This post is for anyone still considering buying this amp.
After a week of listening...I still pronounce it excellent. I'm still really happy with the musicality of this amp and glad I've purchased it.
It's got terrific bass, and a non-murky, very transparent presentation. Everything seems very "fast" - attack time of instruments. Vocals excellent. No complaints at all. It's very enjoyable.
This amp is dead quiet at idle. You can't even tell it's on. I put my ear right up to the La Scalas. No hiss, no nothing. This is THE quietest amp out of the dozen and a half or so amps I own: tube, solid state, D, chip, you name it. This one is spooky quiet so therefore there's nothing bugging you in those quieter music passages.
I forgot to mention -- zero turn on noise. Upon power down/turn off --a tiny little noise. On a scale of 1-100, that turn-off noise would be about a 4. It's a very low volume thing, not loud at all.
Per every discussion on every Internet forum, much babble ad nauseum about "specs" and how this thing cannot be any good or will or won't do this or that because of the specs. HMMMM.........
I don't care what all the specifications say:
1) NO. It doesn't run hot. I can touch the heat sink.
2) NO. It doesn't need any special power supply. I'm just using a simple computer type power supply. 12VDC, 2 amp. XRK, in a link earlier in this thread found a similar one on Amazon for even less money than I paid, and 5 amp.
This amp is being used with my Klipsch LaScalas, Emotiva CD player, Magnum Dynalab FM tuner, the E.A.R. phono preamp with a Technics SP-25. And just a simple $9 switchbox.
I guess the only thing I'd nit-pick on the amp is this: The volume pot on the amp is a tad touchy. It's 100K. And I don't have much "throw" to it before it gets really loud. I'm wondering if I were to pull it and run a different "K" would that help that "too loud, too soon" situation? As you guys no doubt understand La Scalas are very efficient and on other speakers this may not be a problem.
Try it and enjoy! Hide it under a big cardboard box and have a buddy over for a listen. Then ask his impressions and how much he thinks the amp under the box should cost.
Mark
Old 6th April 2013, 01:27 PM   #63
xrk971's Avatar
Mark,
Glad this is working out for you. Too bad these are sold out now. I looked at the spec sheet for this chip, it is one of the fewest external parts required for any amp and if you operate it under 5 watts output it is under 1% THD so not bad. Since your are using very nice speakers the LaScalas will be very loud at 5 watts power so there is the reason they sound good: 75% of sound quality is the speakers. I like how they are quiet and simple. I think these are an excellent alternative for desktop pc speaker builds or something that is plugged in as they are not super efficient not being class D. If you want to improve volume controllability try using a logarithmic pot. Keep it at 100k though.
Old 6th April 2013, 03:40 PM   #64
radiosmuck is offline radiosmuck  Canada
radiosmuck's Avatar
I am awaiting delivery of one of these amps and looking forward to connecting it up to my vintage Tannoys, the speakers only draw .085 watts according to Pano's test.
I'll let you know. how they sound.
Old 8th April 2013, 11:11 AM   #65
activexp is offline activexp  United Kingdom
activexp's Avatar
Send a message via ICQ to activexp Send a message via AIM to activexp Send a message via MSN to activexp Send a message via Yahoo to activexp
Mine came today complete with a 3.5mm to 3.5mm signal input lead. I'm going to power it from a 12V 3.5A SMPS. Will post pics and listening impressions later.
Old 8th April 2013, 12:32 PM   #66
radiosmuck's Avatar
A most interesting website, I remember those fashions, we thought we looked so cool. At least we could cast them off as fashions changed, unlike tattoos.
With all your years of experience in the audio industry you look have a regard for the d-amp technology?
For those interested, the little amps are still available.tda7297f | eBay
Old 9th April 2013, 02:16 PM   #67
activexp's Avatar
Looking back, I think those 70's fashions are best forgotten!
Well I try to keep up with the latest trends and have tinkered a bit with class D. I'm not entirely convinced about sound quality although it does have other virtues which can't be ignored.
The TDA7297 board is up and running, looks a little lost in the case which originally house a TA2022 board and toroidal transformer. With a hole pre-drilled for a volume pot mounting the board should be straight forward.
Not quite as easy as I thought. I wanted to remove the 3.5mm socket from the front edge but desoldering the blighter defeated me.
As for performance of this little board I have to agree with everything that Mark2727 has already said. My speakers are a DIY effort using 8" woofers and Tang Band W3-871 for mid and top end, efficiency I guess is average, about 88dB. The amp appears to have no problem driving them at levels which are quite loud enough for me.
To sum up:
It's silent.
It runs cool.
It has good strong bass
It has clear, dynamic mid and top end
It has a volume control that's more like an on/off switch, silent or loud!
It's remarkable for the price
Get one today, you won't regret it!
(Anyone know why the images have the wrong aspect ratio?)
Last edited by activexp; 9th April 2013 at 02:19 PM. Reason: Aspect ratio of images is wrong
Old 10th April 2013, 09:33 AM   #68
danielwritesbac is offline danielwritesbac  United States
danielwritesbac's Avatar
To quote the advertisement: "super shock, for any occasion"
So, I hope it doesn't do everything it was advertised to do.
Hey, I bought one anyway.
It's going to have some serious competition, but we'll see how it does.
DIY Models & AppsClipNipperLM1875TDA7293Powerful Parallel TDA7293 kit ♦ My post has opinion.
Old 10th April 2013, 11:25 AM   #69
radiosmuck's Avatar
What, you have found something even cheaper?
Old 10th April 2013, 11:58 AM   #70
activexp's Avatar
There is this
1.99 British pounds or about 3 USD including shipping. At 3W+3W I doubt that it's serious competition for the TDA7297
What the heck?  It's less than lunch!Hide this!Advertise here!
No free lunch. Godzilla Full Range 9 7th November 2012 08:07 PM
Cheap Lunch? dsavitsk Tubes / Valves 32 16th June 2007 02:42 AM
-: AlmoÇo :- : Lunch :- audioPT Everything Else 10 24th September 2004 03:15 PM
Copyright ©1999-2017 diyAudio
