| Chip Amps Amplifiers based on integrated circuits |
#21 |
If you have slightly different gains, the amplifier won't be exactly balanced. You need to make absolutely sure that the gain of the inverting half is exactly the same as the gain on the non-inverting half. Otherwise one side will be pushing harder than the other. While this will still work, it won't sound nearly as good as a perfect balance.
Cheers, Zach |
#22 |
Hmm, i see...
thanks |
#23 |
If you get the resistors unmatched to tolerance and your using servos, the servos will have to work harder than they should to balance the output or prehaps fail to balance the output so that no current flow between the chips needless wasting output power. If your not using servos then there will be current flowing between the paralleled chips wasting power to the extent of the mismatch.
#24 |
I wasnt planning on using the servos..
guess i'll be matching those parts as close as i can then!
| difference between bridged and parallel? | jarthel | Chip Amps | 5 | 25th June 2007 06:53 AM |
| What to do with a handful of LM3875's-Bridged, parallel, bi-amp etc? | Dr.H | Chip Amps | 7 | 10th August 2004 04:21 PM |
| Bridged Parallel Amp Questions | h_andree | Chip Amps | 11 | 5th February 2004 03:32 PM |
| ZenV4 in parallel (not bridged) | paulb | Pass Labs | 2 | 1st October 2002 12:57 AM |
| Page generated in 0.09670 seconds (61.71% PHP - 38.29% MySQL) with 10 queries |
