Kindly suggest Hi Fi Sound chip
Old 20th March 2013, 12:25 AM   #21
lanchile is offline lanchile  United States
lanchile's Avatar
Originally Posted by pmbrunelle View Post
You can't say discrete is better; it depends on the particular circuit.
I think there's a learning curve you can't get around, which means that my first discrete amplifier will sound crappier than any IC amplifier I've assembled. Nevertheless, that first discrete semi-crap thing is a necessary stepping stone...
a well designed discrete amplifier will "outperform" a well design IC amp
in Quality, sound and in reliability.
Old 20th March 2013, 03:40 AM   #22
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Yes, 'well designed' means paying lots of attention to the PSRR and also to the IMD performance at low level, two areas where (for example) LM3886 sucks. Read the datasheet carefully to discover that LM3886's negative rail PSRR for a typical amp is under 30dB at 20kHz. If implementing LM3886, do what KSTR does and reference the input signal ground directly to the -ve rail to improve matters substantially. Discrete does give the very valuable ability to have filtering on the supplies to the signal stages rather than pollute them with all the HF hash that gets generated on the supplies by the output stage.
<edit> @picbuck - yes indeed, but getting a seriously good power supply (low impedance beyond 20kHz) is a herculean task
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Kindly suggest Hi Fi Sound chipHide this!Advertise here!
Creative Sound Blaster X-Fi sound card w/upgrade GOWA Swap Meet 0 12th August 2012 09:05 PM
HI-FI chip amplifier with single supply needed neazoi Chip Amps 8 21st January 2012 09:06 PM
comparing hi fi sound to car sound biamp Everything Else 12 27th June 2010 06:59 PM
Decent chip amp with asymmetric supply (similar to low-fi LM386)? mr_push_pull Chip Amps 7 21st June 2007 12:47 AM
Do hi-fi parts really sound better? Shaun Perez Parts 54 24th October 2002 03:49 PM
