LM3875 Gainclone Not Working and Stuck to Rail ... - diyAudio
Old 24th February 2013, 11:52 AM   #1
dannyjmf's Avatar
Default LM3875 Gainclone Not Working and Stuck to Rail ...
Hi ...
Today just build a gainclone LM3875 amplifier and found that it is not working ... output stuck to rail ... the circuit i used is i followed from the NS datasheet ...
BTW , i found that in the feedback path there is a capacitor in the schematic By NS. But i refer to some of the DIY projects schematics they are not included ... is it the cause of my problem ... ?
I need serious help here ... any feedback and suggestions are much appreciated and welcomed ...
Old 24th February 2013, 01:06 PM   #2
Bone is offline Bone  United Kingdom
So you used Fig 1.? What were your DC supplies?
Old 24th February 2013, 01:42 PM   #3
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Please post the schematic here so we all talk about the same.
Old 24th February 2013, 02:41 PM   #4
DUG is offline DUG  Canada
Fig 1 or Fig 3?
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 24th February 2013, 02:45 PM   #5
dannyjmf's Avatar
Fig 1 dual supply version ...
Old 24th February 2013, 03:00 PM   #6
JMFahey's Avatar
Ok.
Measure and post voltage on all 5 legs shown (1/3/4/7/8)
Measure from PS ground to each leg, straight at the chip.
Be careful not to let the multimeter tip slip and short to another leg.
By the way: I hope the chip is mounted to a heatsink and that you insulated it with mica+grease (and a screw-insulating nipple if needed).
Also, with power off, measure resistance to ground from leg 4 .
Old 25th February 2013, 05:18 AM   #7
dannyjmf's Avatar
ok ... get it work perfectly already ... caused by bad grounding issue ...
Old 25th February 2013, 10:46 AM   #8
JMFahey's Avatar
Which was .....
Old 25th February 2013, 10:50 AM   #9
dannyjmf's Avatar
1st ... i didnt use the proper star grounding
2nd ... bad soldering joint from the ground to the 1k feedback resistor (which suppose connect to ground because of bad contact it didnt ...)
Old 25th February 2013, 10:56 AM   #10
dannyjmf's Avatar
completed amplifier
Rail Splitter for bridged Gainclone? gruni Chip Amps 22 7th March 2013 03:12 PM
the best transformer rail voltages for gainclone? araven Chip Amps 2 30th September 2006 11:31 PM
LM3875 rail voltage question Greg3333 Chip Amps 2 25th April 2006 10:34 PM
LM3875 BrianGT kit not working waltson Chip Amps 9 28th January 2006 09:00 PM
Gainclone single rail PS question KT Chip Amps 11 30th September 2004 07:47 AM
Copyright 1999-2017 diyAudio
