X2 Line capacitors - Page 3 - diyAudio
Old 2nd March 2013, 10:55 AM   #21
Originally Posted by argonrepublic View Post
Can I expect any immediate improvements using X2 capacitors across my AC line? ........................
Originally Posted by AndrewT View Post
The primary purpose of an X2 capacitor across the Live and Neutral of the Mains supply is to attenuate the interference .....................
Originally Posted by DF96 View Post
Different issue..................
Is it a different issue?
reducing interference can have a very audible effect.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 2nd March 2013, 11:49 AM   #22
DF96 is online now DF96  England
Maybe not a different issue. When people talk about putting X2 caps across the mains I just assume they are talking about low value caps inside the equipment. Mostly this is what they mean. Putting big caps across the mains outside the equipment is not something I would do, so perhaps I forget that some people encourage this.
If a mains filter is needed then a mains filter may be the best option. Simply slapping on a big cap and relying on wiring inductance seems a bit crude. As I said, it could increase induction of noise because it increases the noise current in the mains wiring.
Old 11th March 2013, 11:47 PM   #23
tsiros is offline tsiros  Greece
tsiros's Avatar
Send a message via MSN to tsiros Send a message via Skype™ to tsiros
and what happens when the capacitor fails? because they are known to do. and when they do, they short out.
maybe i sound paranoid, but the only thing i put is the iso standard mains plug with fusebox and switch. after that is the transformer.
Old 12th March 2013, 11:13 AM   #24
X2 caps are designed to fail open circuit. In fact, that is one of their weaknesses as voltage spikes progressively erode the capacitor away so it reduces in value over a number of years.
Y caps are even safer - you are supposed to be able to trust a Y cap with your life!
Old 12th March 2013, 11:40 AM   #25
Originally Posted by tsiros View Post
.........maybe i sound paranoid, but the only thing i put is the iso standard mains plug with fusebox and switch. after that is the transformer.
You are potentially dangerously paranoid.
Understand the science before you play with mains electricity.
regards Andrew T.
Old 12th March 2013, 05:53 PM   #26
Location: On a hill, in a wooden shack, next to the woods, in Somerset.
May I add a word of warning, gleaned from personal experience, to anyone putting film caps (especially as large as 10uF) across the mains. They will hold their charge for an awfully long time because there is very little to dissipate it. And they can pack quite a punch when you finally put your fingers across the terminals. I doubt it would kill you unless you are wearing a pacemaker but you will be breathless and disoriented for a second.
Mine was a 400V 10uF Wima MKP10 that had been sitting on the bench for a few days after playing around just as you are discussing here. I would say that it's probably worse as a shock than your average touching the mains. FWIW I found nothing improved the sound and if anything made it worse. And that is consistent with my general experience and view on all things to do with mains conditioning or filtering, though I can't see anything against a common mode choke or keeping voltage spikes away from your electronics. Personally I would go to the items that are causing the mess, fridges etc., but even then I'm probably more interested in making my lightbulbs last longer than in cleaning up the mains.
Old 12th March 2013, 06:45 PM   #27
Osvaldo de Banfield's Avatar
Location: Barrio Garay,Almirante Brown, Buenos Aires, Argentina
Cris: the solution is obvious: a 1 megaohm in parallel with the cap will discharge it in few seconds, and no risk is present.
Osvaldo F. Zappacosta. Electronic Engineer UTN FRA from 2001.
Argentine Ham Radio LW1DSE since 1987.
Old 13th March 2013, 01:20 PM   #28
Yes, Osvaldo, of course I'm aware of that now, , but 30 years of having capacitors littering your desk and never doing you any harm had led to me to an easy (and unjustified) complacency. Nor, even now, would I mentally judge that a capacitor of that size could hold enough charge to have more than a trivial physical effect. Sure, with 10,000V I would be careful, or with 10,000uF, but 10uF? If you get my drift, then you can see why it is an easy mistake to make. I just thought it might be worthwhile warning others about a not-that-obvious potential danger.
Old 13th March 2013, 07:20 PM   #29
Mooly's Avatar
And just to add that any resistor MUST be continuous "high voltage rated". Just calculating wattage is no good, resistors have voltage ratings and failure of ordinary resistors used like this is an industry wide problem.
I can tell you from experience that even a 0.1 uf charged to peak mains voltage (on 240 volts mains) can bite if you have damp hands. Many old TV's were like this and it was common for techs to get a belt off the mains plug of a disconnected appliance. One tech used to stand there swinging the mains lead smashing the plug tops off any that got him
PA100 (x2 LM3886) FeedBack Capacitors Al1B Chip Amps 9 3rd December 2011 07:57 PM
X2 capacitors in audio stevomaso Parts 2 11th September 2011 01:56 PM
X1/X2 Capacitors AC in, adding noise to the system!? Destroyer OS Construction Tips 21 24th December 2010 09:07 AM
X2, AC Line Capacitors Speedskater Power Supplies 7 2nd December 2010 03:29 PM
FS: Antek Torroid 40V x2, 18V x2, 800VA dweekie Swap Meet 0 7th July 2008 12:24 PM
Copyright 1999-2017 diyAudio
