LME 49810 Kit
LME 49810 Kit
Old 17th February 2013, 09:22 PM   #1
thor61 is offline thor61
Default LME 49810 Kit
Hello everyone Has anyone built this amp ? If so could you share some of the details ? See link > Compact SeriesClick the image to open in full size.
Old 21st February 2013, 06:54 AM   #2
Sebastiaan is offline Sebastiaan  Netherlands
Highly recommended! Mr. Panson know his stuff very well and this is one of the rare DIY PCB designs that is actually very good. I believe from own experience PCB design add's (or degrade) more to audio design then choice of components.
It is no surprise this kit has such an extraordinary low THD levels, since again the PCB design is excellent, and fits most of the rules to achieve low distortion
With kind regards,
Bas
Old 21st February 2013, 06:02 PM   #3
How about the sound quality ? How good are the LME series based amps ? Why don't more people use them as opposed to something like the 3886 types ? I have ordered a pair, But still waiting for a shipping conformation and more information... from Mr. Panson
Old 22nd February 2013, 10:09 AM   #4
I have used the LME driver chip in a very successful commercial design. THD spec and sound wise it is very hard to beat. The LM3886 has it's own place, but superior results can be made with this driver IC and a good discrete power stage. I think Panson pretty much nailed it down, and is about the best you can get out of it.
With kind regards,
Bas
Old 22nd February 2013, 06:21 PM   #5
Sebastiaan, Thank-you for this information, I now feel inspired to try to build a amp based on those pcb's once I get them.
Old 12th February 2018, 04:41 PM   #6
Telstar is online now Telstar  Italy
Strangely I also didn't see more kits based on this chipamp. Looking for a higher power version of the one made by Panson (at least 250w/4 ohm).
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 12th February 2018, 08:07 PM   #7
indianajo is offline indianajo  United States
indianajo's Avatar
IC is out of production. I got 24 of the last distributor stock but no boards are stock. Panson board had good reputation but required 5 leg internal diode transistors, so not for the bargain basement type. Last I checked his webstie was under maintenance.
Dynakit ST70, ST120, PAS2,Hammond H182(2 ea),H112,A100,10-82TC,Peavey CS800S,1.3K, SP2-XT's, T-300 HF Proj's, Steinway console, Herald RA88a mixer, Wurlitzer 4500, 4300
Old 12th February 2018, 08:09 PM   #8
Oh, that sucks.
Old 13th February 2018, 05:34 AM   #9
tomchr is offline tomchr  Canada
tomchr's Avatar
You may find this to fit the bill: Modulus-686: 380W (4Ω); 220W (8Ω) Balanced Composite Power Amp with extremely low THD
Tom
Modulus-686: 240W/8Ω @ <0.00025% THD. Modulus-86: 40W/8Ω @ 0.000054% THD. DG300B & Other Tube Circuits.
Neurochrome : : Audio - www.neurochrome.com - Engineering : : Done : : Right
Old 13th February 2018, 12:54 PM   #10
I did consider it, yes, Tom. And i may get it anyway next month
LME 49810 KitHide this!Advertise here!
LME 49811 Project? jaya000 Chip Amps 31 1st March 2017 08:08 AM
LME 49810 with NMOS output stage 1000W @ 4 OHM NMOS Solid State 15 23rd September 2011 05:23 PM
LME 49713 + LME 49600 pre amp klewis Chip Amps 16 4th February 2011 01:15 PM
LME 49810 SPICE model anyone? rsbonini Software Tools 0 15th March 2010 05:51 AM
LME 49810 CFP output stage sasmit Chip Amps 3 6th October 2009 07:45 AM
