741 Op Amp Drop in Replacement
Old 15th February 2013, 08:25 PM   #1
jwatts is offline jwatts  United States
Default 741 Op Amp Drop in Replacement
I was wondering if some people could recomend me a better peforming drop in replacement for a 741 Op-AMP. I would prefer if it come in a surface mount package rather than a dip.
Old 15th February 2013, 08:45 PM   #2
ekaerin is offline ekaerin  Sweden
ekaerin's Avatar
If possible. Can you give us more details about the circuit where you intend to use the OP.
A schematic would be perfect.
Chances are that a high performance OP may become unstable or the like if just "droped in"
Regards / Mattias
Old 15th February 2013, 08:51 PM   #3
I will be using it for active 2nd order Bessel active filter application.
What do you mean by unstable exactly?
Old 15th February 2013, 09:02 PM   #4
DUG is offline DUG  Canada
Schematic?
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 15th February 2013, 09:12 PM   #5
I dont have a schematic handy.
Old 15th February 2013, 09:21 PM   #6
ekaerin's Avatar
Ok. Filter app. What is the highest frequency the filter will output.
OP amps may oscillate from lots of things like impedance on its input , gain / feedback structure & power rail decoupling
to name a few.
I once changed OP amps in a soundcard and it turned into an AM receiver although I checked everything....
Old 15th February 2013, 09:37 PM   #7
15 kHz tops. I will be building both high pass and loss pass circuits with the 741s.
Old 15th February 2013, 10:27 PM   #8
dchisholm is offline dchisholm  United States
dchisholm's Avatar
The '741 was never a high-performance device in audio applications, but it was cheap and easy to use.
15 KHz active filters of any complexity, especially the hipass, are really pushing the limits on 741-class devices. If I had to suggest an alternative without any more information to go on, I'd look at the TL07x family. For truly modern parts check out the (former) National LMExxxx series, or OPA604/OPA2604.
Dale
Old 17th February 2013, 08:41 AM   #9
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
"Drop in"?=TL071 .
But you must really post the schematic, for a more complete amswer.
Are you using an old schematic picked up somewhere or designing a new one?
Old 17th February 2013, 11:40 AM   #10
Mooly's Avatar
This is what we mean by unstable,
http://www.diyaudio.com/forums/analo...avent-you.html
I'd go along with Dale and JMFahey and recommend the TL071 too. It will be a massive improvement over the 741 in all respects.
741 Op Amp Drop in ReplacementHide this!Advertise here!
5532DD op amp replacement? BeerCan Digital Line Level 22 20th December 2011 01:01 AM
741 op.amp works, tl 071 is oscillating? zoranaudio Solid State 42 16th February 2009 10:43 AM
OP-amp replacement... Lyra Solid State 6 20th April 2006 09:52 AM
OP amp replacement mieze245 Chip Amps 0 19th September 2004 06:46 PM
replacement op-amp ? iceman Solid State 2 14th July 2003 02:28 PM
Resources saved on this page: MySQL 10.00%
