TDA7294 - no output - diyAudio
Old 14th February 2013, 06:52 AM   #1
child1 is offline child1  Denmark
Default TDA7294 - no output
Hello...
I have been building a subwoofer plateamp based on the TDA7294 chip. I have read a lot about the chip on this page and others, but haven't found the reason for my problem still.
There is simply no output from the amp! Only a vague humming noise from the speaker when i put my ear very close to it. Flipping the mute and stndby switches dosn't seem to change the humming.
Measurements:
V+ = 32.8V
V- = 32.9V
Mute/stndby pin both > 25V
No DC offset on output
So what can it be? I have attached a schematic and PCB drawing
Please help !
-Mads
Old 15th February 2013, 05:20 AM   #2
Are you sure your V- is 32.9 volt and not minus 32.9 volts. Could be just typo but I should confirm.
Gajanan Phadte
Old 15th February 2013, 05:36 AM   #3
Yes, sorry it is of course -32,9 just a typo
Old 15th February 2013, 07:06 AM   #4
Well... it turns out that it does indeed work. Apparently the output from my soundbar project to the sub is either to low or not existing at the moment. So I will have to look into that instead.. :S
Optimizing TDA7294 Output bcmbob Chip Amps 838 21st February 2017 09:48 AM
TDA7294 output stuck to -Vsupply kroto Chip Amps 9 21st February 2013 05:36 PM
Tda7294 e_fortier Chip Amps 2 27th November 2008 02:33 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 07:58 AM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 03:08 PM
Copyright 1999-2017 diyAudio
