ebay amp kits - Page 5 - diyAudio
Old 29th August 2013, 09:50 AM   #41
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
My opinions so far:
LM4766- worst PCB design, most parts good, amplifier IC, fake.
TDA8920BTH board, the Juan Jing one, pretty good design, sounded pretty good but most parts were chinese slave made.
IRS2092, good design, did not work with original parts, had to buy new ones. Driver and output transistors.
Mostly they are pretty good, but i rather design my own and get parts from digikey or TME.
Old 29th August 2013, 10:35 AM   #42
If you want to design your own PCB, then you must understand what allows a PCB to work properly.
The same applies to modifying an existing PCB to improvement the performance of the circuit.
If you need to learn, then build anything and learn after that.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 29th August 2013, 11:43 AM   #43
Mihkus's Avatar
I havent design many amps but YOU have told me alot, I have built few amps, and they sound wonderful.
Your the superman of this forum...
Old 12th March 2016, 11:19 AM   #44
verde57 is offline verde57  Romania
Which one is better schematic wise?
A Pair DC 35V 55V 470uF 100V 200W 200W Superpower Amplifier Board vs Dartzeel | eBay
2pcs One Set 2X120W 8ohm Toshiba TTC5200 TTA1943 Amplifier No Heatsink | eBay
Old 13th March 2016, 09:46 AM   #45
please I need to buy on of these kits that work with 55V DC, which one?
Old 13th March 2016, 10:06 AM   #46
The first link is to a site that does not know how to tell the truth.
Don't trust it.
The second is much closer to advertising reliable targets.
A 2pair 1943/5200 output stage has a maximum (reliable) output of around 100W.
The recommended 50Vdc supply will achieve ~100W into 8ohms speakers.
Alternatively use a 28+28Vac transformer and your maximum power output target becomes 100W into 4ohms, the 1943/5200 might even work well @ 120W into 4ohms fed with a 30+30Vac transformer.
regards Andrew T.
Old 13th March 2016, 11:06 AM   #47
forr is offline forr  France
forr's Avatar
Verde57,
Forget the first link.
The "Toshiba" circuit should have a constant current source instead of R20.
A fact encouraging to not get it.
Old 13th March 2016, 03:34 PM   #48
Thanks, any other suggestions for amps payable thru paypal are greatly appreciate.
Old 8th January 2017, 10:42 PM   #49
Jsixis is offline Jsixis  United States
thanks for the center tap explanations.
Another reason the items from overseas cost less, there is not a CEO demanding millions and 20-30 VP's demanding 300k a year.
I know nothing, so learning is really awesome.
Old 11th January 2017, 07:42 AM   #50
hello guys, this is not "ebay" product , but did any of you try the the FK667 kit from qkits.com?
https://store.qkits.com/100-watt-ste...ifier-kit.html
Ebay kits littlerick Chip Amps 23 20th September 2012 11:40 AM
Chinese Kits EBAY tatolovera Chip Amps 5 22nd July 2011 08:05 PM
Chinese "knock off" kits from ebay tmort Solid State 15 27th May 2009 01:46 PM
Ebay Dac Kits OK? Zero One Digital Source 2 19th February 2009 02:40 PM
Foster (Fostex) & Tangbabd MTM kits on ebay cjh Multi-Way 2 18th April 2004 10:23 AM
Copyright 1999-2017 diyAudio
