Ampliffier layout, Hum, EMI - diyAudio
Old 10th February 2013, 05:59 PM   #1
Default Ampliffier layout, Hum, EMI
This is my Barbaric amp amplifier. Thanks to the members of this site I have amplification that perfectly suits my needs and sounds better to me than anything that I have tried to use in my system. I know very little about this and am looking forward to learning. I currently have 60Hz hum in this system. It is similar to the sound of passive pickups in a guitar while idle. It is not extremely loud. At this point, I am so pleased with the sound of this setup that I'd rather this amp with the hum than any of my others but would like to learn about EMI and how to get around it and avoid it.
Old 10th February 2013, 06:58 PM   #2
nigelwright7557's Avatar
One of the main hum problems is caused by poor grounding.
There should be one star ground point where all the grounds meet.
One of the main culprits is the smoothing capacitors because they get very large surge currents as they charge up on each mains cycle.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 12th February 2013, 12:32 AM   #3
Jsixis is offline Jsixis  United States
twist all wires that have ac, that should eliminate your hum, another thing any wires that cross each other should be 90 degrees. Then once you get the top and sides on that should help especially if you have flouresent lighting.
Old 14th February 2013, 02:06 PM   #4
Should the base of an amplifier me constructed from a material such as steel to conduct or absorb magnetic field?
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
does some know how to build a 60hz hum Eliminator which stops the 60 hz hum?? prorms Solid State 21 13th August 2011 07:26 PM
Hum in right speaker becomes hum in both speakers when headshell detached THX1979 Analogue Source 16 24th June 2011 08:59 AM
Simple SE optimum layout for hum webby Tubelab 22 30th July 2009 03:55 AM
preamp layout and hum problems - help! Tex Houston Solid State 1 11th June 2007 09:44 AM
Copyright 1999-2017 diyAudio
