Old 8th February 2013, 06:10 PM   #1
Default On speaker protection
Hi all,
I'm about to build an LM 3886 stereo amp using the chipamp.com amp and power supply boards. (I got a good deal on ebay) I'd like to have some kind of speaker protection for my old 8 ohm KLH Model 17s. I've read about speaker protection circuits, large caps in series w/ the output (do they need to be non-polarized?), fuses on the power supply rails. How about fuses on the outputs themselves, or circuit breakers? What value and would that be fast enough?
I would value simplicity over ultimate protection. These speakers aren't that rare, etc.
Keith
Old 8th February 2013, 06:25 PM   #2
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Use the Triac crowbar circuit favored by Peavey and a ton other Pro PA sound equipment makers.
Old 9th February 2013, 01:04 AM   #3
djoffe is offline djoffe  United States
assuming you don't listen at crazy high levels, a 1A slow blow fuse isn't a bad solution. There are some problems with it, but it's simple, and may do the job for you.
Old 9th February 2013, 01:47 AM   #4
andrewlebon's Avatar
Default speaker protection
Hello
greetings can this circuit work for speaker protection
warm regards
andrew lebon
[image][/image]"It's Better to try and fail than to never know and always wonder"
speaker protection soundnovice Multi-Way 6 1st December 2011 10:25 AM
speaker protection (OR) overload protection myanmar Solid State 7 13th July 2006 08:21 AM
FS: Niles HDS-6L speaker selector w/ speaker protection. Spasticteapot Swap Meet 0 27th May 2006 11:14 PM
Speaker Protection senee Solid State 0 17th May 2005 06:53 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
