Looking for TDA 2050 circuit boards
Old 26th March 2013, 01:25 AM   #21
Jsixis is offline Jsixis  United States
Originally Posted by nigel pearson View Post
Celsius and Fahrenheit .
16 C = 61 F
28 C = 82 F
To a good approximation .
451F = burning point of paper ( it is said ) .
16 to 28 C is a typical British summer .
I'm not good at Celsius, here in the states it is ignored except for scientists.
So I guess I am hoping on a 10 degree C day
Old 26th March 2013, 09:58 AM   #22
nigel pearson is offline nigel pearson  United Kingdom
In the UK we mix up metric and imperial for very practical reasons . I am not a mechanical engineer but have work around it for years . We buy aluminum is lets say 2 x 1 x 1/4 inch L section 4 meters long . Nearly all the guys I work with are comfortable using inches ( 50 to 70 years old ) , we conceptualize them better . However to mix up standards is common . For example I will say could I have a 6 mm shaft with 1/1000 " running clearance . A Rizla cigarette paper is 1/2000 " . 2 x 1 x 1/4 is US/Canada sourced and is cheaper . 4 metres is a standard length for shipping . 1/4 = 6.35 1 = 25.4 . When given a cosmetic finish we have 6 x 25 mm .
I came up with a very simple formula for my boss who hates maths . ( 22/28) x ( d x d ) is the diameter to area formula ( he needed to know 4 mm square ) . That comes from Pi = 22/7 rather than 3.1415927 . The attraction of inches is the use of fractions . A turntable centre spindle is 9/32 inch ( 7.144 mm ) . The real spindle is usually about 7.1 mm to allow for shrinkage after pressing .
I would be very interested in the bridged version of TDA 2050 . Another idea I have yet to try is a class A for TDA2030/40/50 . If an op amp is forced to conduct to usually the negative rail we consider it to be working in class A ( typically below 5 mA ) . If we set up a constant current source we could try pushing the TDA 2050 into class A , after all TDA 2050 is just a high current op amp . A TIP2955 , 2 x 1N4007 ( I always use the 1000 V version ) . 1R 3 W emitter = about 1.3 A , 220 R 3 W for the bias . I suppose a constant current sink would be OK as that resembles a typical 1970's NPN class A stage ( TIP 3055 ) . If the TDA 2050 chip can stand the strain is another question . Some will question a slow transistor . In class A it is less important and sometimes works best . The power supply would have to be beefed up . If the CCS could be signal activated is another question . If so the standing current could be reduced . Replace the 220 R with a cheap MOSFET Perhaps ? The FET wll be faster than the TDA2050 or TIP 2955 . If so the current should be always available ahead of what the amp can do . This is not class AB so not so critical .
Old 26th March 2013, 12:18 PM   #23
radiosmuck is offline radiosmuck  Canada
radiosmuck's Avatar
I came up with a very simple formula for my boss who hates maths . ( 22/28) x ( d x d ) is the diameter to area formula ( he needed to know 4 mm square ) . That comes from Pi = 22/7 rather than 3.1415927 . The attraction of inches is the use of fractions . A turntable centre spindle is 9/32 inch ( 7.144 mm ) . The real spindle is usually about 7.1 mm to allow for shrinkage after pressing.
Things designed in metric are easy, it is when you convert imperial to metric is when it becomes difficult, the dimensions all become "odd ball".
Old 26th March 2013, 01:48 PM   #24
As said engineers are forced to use both . Whether urban myth or not I am not sure ; it is said a space probe was lost on Mars because someone was thinking inches when others metres . It rammed the planet at speed . Also an aircraft was wrongly fueled when converting to metric for buying jet fuel . Just to make it more complex our gallons are different to US . We have Stones for weight ( 14 = 1Lbs ) . I am OK with Stones or Kilo's . I am baffled when someone says they are 200 lbs .
I always remember the old BTU of , to raise one pound of water through one degree Fahrenheit = 1BTU . Also SHC( water ) of 4.183 j/g degree K .
Our old money was 12 Pennies one Shilling . 20 shillings one Pound ( with Groats , Guineas and double Florins thrown in for good measure ) . It kept you sharp thinking about it . I miss it and found divisions of 12 very easy . We had 1/8 pounds called Two and Sixpence pieces , the double versions called Crowns .
At college we were always told keep it in fractions if we can . Pocket calculators were rare then . I still keep things in fractions when possible . Younger people will have no concept of this . We were marked down for using answers unlikely to be seen in real life examples when doing calculations . 22/7 was Pi . Inch system often is expressed in fractions .
British engineers think nothing of using which ever system works best . Typical conversation would be . 6 mm looks OK for that . OK I will start with 1/4 inch stock , grind , polish , harden it . It is obvious that the metric system is marginally preferable . I hate technical drawings in inches , I nearly always convert them . Many will not realize that the ancient BA ( British Association ) thread was based on metric . It is not the same as modern metric threads . Older engineers take a dim view of young ones who can not think in inches . It can even lead to being charged more !!!
I would guess Indian engineers equally use to having both systems in use ?
Some people buy toys to mind-train . Engineers don't need them .
Old 26th March 2013, 02:28 PM   #25
radiosmuck's Avatar
I'm orignally from the UK.
In South Africa during the early 70's, a British electronics company I worked for decided to go metric. They then picked an "M" day, that is a day when all the imperial drawings and specs would be replaced with metric equivalents, it was planned like a military operation.
Like most military operations it was not thought through that well, the machineshop still had imperial leadscrews and dials, no cnc back then. All the machinist had to convert their new drawings back to imperial, no calculators back then either.
I seem to remember we went back to imperial after a few weeks.
Old 26th March 2013, 03:00 PM   #26
Sorry we got off of TDA2050's , great to reminisce . This last bit below .
Garrard motor shafts were 4.91 mm . Neither metric nor imperial . Garrard size . We guessed they started with 5 mm stock , hardened ground and lapped . Look after your Garrard bearings , if not it is big trouble . If in trouble take a high grade 5 mm pin . Dill the original self alining bronze bearings to take x 10 x 8 x 5 mm sintered bronzes replacements . Make it a snug push fit ( never a tight fit ) . The worst bit will be extracting the shaft from the rotor . Ream the rotor 4.91 to 5 mm . Fit new shaft with loctite or similar . The shaft should be to > 64 Rockwell hardness and 1 micro finish if possible ( 6 will do ) .
Old 27th March 2013, 01:52 AM   #27
Default Pics os set up
Here are some pictures I took tonight.
This is my 1st build. I've had the parts for years except for the assembled 2.1 board. I had the system sitting on my workbench playing with no earth ground and small heat sinks you see on lm317 chips. It worked fine till I turned the sub up to stoopid with 4 ohm load
This will be my workbench amp for the time being.
I want the rca's on the front so I can switch sources easily and a 1/4" guitar input for when I work on guitars.
Yes it is machine grey, only spray paint I had in the shop. I plan on making another front face, just scratched the 1st one up during the learning curve.
I do have some questions, the chassis is plastic;
My star ground on one of the transformer screws.
I need to run a wire from the earth ground of the plug to that point and from the negative lead of the large capacitors. Can I use the -in on the board where the negative secondary is attached?
On the speaker output do I need to run a wire from the negative posts to the star ground? The heat sink is negative, another wire?
Just want to make sure I get the ground proper.
Since the speaker output is a long run should I put a small cap across the outputs at the binding posts? Are twisting those wires required?
The transformer is a radio shack 12.6-0-12.6 2 amps. I know it is small but I had it on hand and it fits in this box. So I put a 2 amp fuse on the mains wiring and 1 amp fuses on each leg of the secondaries?
Yep, I know I forgot the power switch lol
Old 7th April 2013, 02:52 AM   #28
I fired this amp up last night. Since I broke my 5/32 drill bit off in the heat sink I had to switch to a pair of 496 CPU coolers with fans, so I had to add an adjustable power supply for those.
The amp sounds fine. My radio shack 2 amp 12.6-0-12.6 worked out to 28 volts at the board with my house line voltage of 127volts and music at a loud volume.
For an input I used a sony CD walkman with the volume all the way up.
I tried it at 1/2 volume and it wasn't enough to drive the speakers to an acceptable level.
The test speakers are a set of voigt boxes I made a long time ago with Parts express 69 cent full rang driver, their FS is 100hz, rated at 89db @ 1 watt. For the sub I used my single 10" bass speaker I designed using a Eminence Delta 10 woofer, it is around 107db @ 1 watt so it really over powers the stereo set.
Some of the quirks;
The sub channel doesn't work unless the main volume is turned on and it is super sensitive, almost to the point of being impossible to adjust. You have to just barely turn it on to get that good sub sound where you don't hear it but you feel it.
It is crossed over too high. I have read where these are at 200hz and it seems to be there.
I may try adding a resistor on the output so I can actually adjust the volume of the sub. A more inefficient sub would definitely help but finding 8 ohm subs may be a challenge.
The tone control is also quirky, on this system it sounds best at about 1/3 of the way up.
Using my I pad analyzer with c weighting I managed to get it really close to the munson curve. The system is really heavy around the 250hz region, the sub seems to be right below that with a big boost down to 60 hz. The I Pad is known to be very questionable below 100hz without a break out box. Once my computer system is set up in the garage I'll be able to get better readings.
With no music the DB rating in my garage was 48db, the fans were 59db.
(way to annoying)
I played music as high as 89db but prefer it around 70db.
To get to 70db the volume is about 1/3 up, at about 50% you can hear the distortion kick up (90db) and from 50% to all the way up all you really get is more distortion but still sounds better then boom boxes.
I have the fans set at 9 volts so I will turn them down to the lowest I can get them to still work. 3 hours of music created no heat I may even try them with the fans off.
My test CD's were AC/DC Black Ice, Ozzy Osmosis and Queen Its a Kind of Magic.
For a 1st build I'm satisfied. I plan on ordering a selector switch so I can have more inputs and once I get some more drill bits I will attempt to put the original heat sink back on. I will also use my drill press the next time.
I also have some Pioneer 3 way 1100 speakers with a 10 inch woofer that I will test this out on next weekend and post here along with more pictures.
I do have another of these boards so I may try to backward engineer these and see if there are any tweaks. The 5533p's are in sockets so they can be swapped out.
Once my part time weekend work is over I have a pair of boards that use 2050 chips and those will be my next build.
They are bare boards so I can use better components and possibly bridge them.
Thanks for all the help!!
Old 8th April 2013, 09:41 AM   #29
Bridging would be interesting . Try if you can the same sound levels . The arguments can be bridging gets rid of helpful traits ( ie , bad ) . Or bridging stops returning speaker current through the ground ( ie , good ) . On a tube amplifier one can do tricks with that ( SE driver PP output in long tail pair ) .
If I get time I will try a TDA 2040 in classA . The current source a LM317 ( or 337 , perhaps better ? ) . In theory a 1 R resistor should give 1.25 amps . The chip is good for 3 amps . All I need is a big heat sink . My eyes say to me the heat will be a problem ( if it works at all ) . One advantage over traditional class A amps is the TDA2030/40/50 will revert to class AB above 1.25 A . I suspect even 1/2 amp will be doing something ? The LM317 is fast enough to do this . Also class A does not require speed . What should happen is the crossover distortion which is probably higher than discreet amps will be far lower . It will not be dramatic in measured terms . The mechanisms that produced it will be eliminated . Shown is the single voltage rail version . There are 60 V 317's . Look at application notes for additional capacitors .
Old 8th April 2013, 12:51 PM   #30
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
If the chip itself is class AB then how the heck can you have class A
Well you have first stage of AB after what you have A. Damn electronis you scary!
Ohh yeah, now i got it sorry
Looking for TDA 2050 circuit boardsHide this!Advertise here!
TDA 2050 bridge version andreidaniel Chip Amps 2 8th December 2011 03:09 AM
Tda 2050+bd249/bd250c Alek Solid State 2 1st February 2010 07:04 PM
Nr 50 TDA 2050 fosforo Vendor's Bazaar 1 19th June 2008 08:36 AM
tda 2050 - heatsinking and schem scaesic Chip Amps 1 20th June 2007 02:04 AM
