| Chip Amps Amplifiers based on integrated circuits |
I have a couple of STK4044 modules. I am about to attempt firing them up. The PCB has labels -VDC, +VDC, Gnd, Gnd, Gnd, +sig, +sig, HP, HP.
I am assuming, that sig+ is the input for each respective channel and HP is the output power from the module. Are all 3 grounds shared in a chip amp like this? Can I feed these modules with a preamp? I have a transformer, rectifier, 6800uF 56Volt capacitors and 500ohm resistors to power these up. Is there anything else I need? The picture is not very large but may be readable. |
#2 |
Just a minute.... not very large
How big did you want it.I think you need to do some checks before firing it up. The speaker output will go to the coils (+S I would have said, just from you asking and me looking) so thats total uncertainty. Have a measure and refer to the data shhet for the IC to check the inputs, but once the speaker out is determined the other has to be input by default.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#3 |
My scan didn't work out so well. I was hoping it would be more legible. I will take some time and study the datasheet.
Thanks |
#4 |
I got caught attaching that picture... the site went slow... if you can't see it refresh the page
![]() Your picture is massive
#5 |
Why not check here?
Complete datasheet. STK4044 pdf, STK4044 description, STK4044 datasheets, STK4044 view ::: ALLDATASHEET ::: Looks like pin 3 is the only ground to be connected.
Sooner or later you end up with TANDBERG |
| Hookup wires for tube amp | MGH | Parts | 11 | 23rd November 2012 12:13 PM |
| shielded hookup wire for amp, where? | gychang | Parts | 3 | 29th May 2011 08:08 PM |
| crossover amp hookup | jonesk1978 | Car Audio | 2 | 26th February 2009 11:40 AM |
| Question on Piezo/Pioneer 8" FR Hookup... | LowVoltage | Full Range | 7 | 19th May 2006 05:05 PM |
