Old 1st February 2013, 09:35 PM   #11
KMossman's Avatar
Send a message via Yahoo to KMossman Send a message via Skype™ to KMossman
Can I get strawberry sauce on mine?
Old 1st February 2013, 11:14 PM   #12
Bando is offline Bando  Canada
Ok guys, yes a battery can still be dangerous.
I just thought that with tubes being exposed, being very hot and having high voltage wasn't that great of an idea with small children around.
I have touched a car battery with both hands on the terminals and nothing has happened. From what I remember from school you cant even feel electricity until 40 or so volts.
I get it, no matter what is used you have to be careful. I just wanted something that sounds fanastic that can live in a room and not be brittle or overtly dangerous. Since my toddler loves throwing things and I am sure that kids will be kids even when there older I want something that can stand some abuse.
If I cannot have decent sound and an amp that is more rugged than I won't build an amp.
Old 1st February 2013, 11:44 PM   #13
cotdt is offline cotdt  United States
Send a message via AIM to cotdt
Don't be discouraged. Any amplifier design can be built safely, be it SS or tubes. The tubes don't have to be exposed. It can be put on a PCB and everything will be inside the chassis. Tubes don't really get that hot. In the old days, people used candles and kerosene lamps and had 10 kids, and they somehow managed. So don't be discouraged.
Old 2nd February 2013, 12:38 AM   #14
I did not now tubes could be enclosed, I thought they had to be exposed to breathe.
I am gathering it is execution on the part of the builder rather than circuit design or voltages that plays the biggest part in safety.
Old 2nd February 2013, 02:21 AM   #15
Right, there are a lot of famous tube amps with the tubes enclosed. If you include guitar amps, then most tube amps actually you can't even see any tubes.
Old 2nd February 2013, 04:12 PM   #16
johnr66 is offline johnr66  United States
Actually low voltage DC can injure you, not by shock, but by electrolysis damage to your cells. You have to be in contact for a while, but keep that in mind when working around it.
My only issue with tubes is that the cost of quality parts can get downright costly. Look at the output transformers. You need two for stereo. If you're starting out, IC amps are simple and cheap. Just be sure to get authentic parts.
Building RH84 SE tube amp. Forsman Tubes / Valves 152 29th April 2012 07:41 PM
Building my 1st tube amp samer0214 Tubes / Valves 42 11th November 2011 03:31 PM
Building a tube integrated amp elgee Tubes / Valves 11 16th October 2011 12:23 AM
need help building tube headphone amp rouslan Headphone Systems 5 22nd October 2006 02:53 AM
First time building a tube amp: Help please JAZZ2250 Tubes / Valves 36 28th June 2003 09:37 PM
Page generated in 0.07694 seconds (100.00% PHP - 0% MySQL) with 9 queries
Copyright ©1999-2013 diyAudio
