LME49810 biasing procedure temp comp and simple resistor - Page 3 - diyAudio
Old 21st March 2013, 05:03 PM   #21
Default LM4702 biasing
Hello R.,
I bought a pair of LM4702 amps prebuild driving a single pair K1058/J162 ;one of the channel Voltage measuring across 0,22R is
30V (simple bias system ,just a VR 1K) instead of 20mV of other channels ;this value also found at the sink-source of its LM4702 .
I swapped it with a new LM4702 ,the initial voltage was 10 volt ,after
2 hours 6V ,VR at minimal setting .(still FAR from 20mV )
Help is needed ,please .
Old 21st March 2013, 05:24 PM   #22
palstanturhin's Avatar
Let me understand...
You measured 30v across the .22 resistor?
In that case your .22R resistor must be faulty.
Old 22nd March 2013, 03:29 PM   #23
Hi P.
Yes ,you are right ne of the 0.22R is faulty .I replaced both with a set
old surplus ,the K162 exploded .will report back one it 's corrected.
Thanks man.
Old 23rd March 2013, 07:52 AM   #24
use a bulb tester.
regards Andrew T.
Sent from my desktop computer using a keyboard
Simple SE Cathode Resistor Values skidave Tubelab 21 10th February 2016 11:50 AM
Simple opamp problem (biasing) - can you help? peskywinnets Solid State 29 29th March 2011 08:59 PM
Mystery resistor in simple audio amp MajorMajor Solid State 93 21st January 2010 08:29 PM
simple se cathode resistor question pforeman Tubelab 4 1st June 2009 05:08 PM
Normal temp of a 2 watt resistor? turbo_slug Parts 18 30th May 2008 11:25 PM
Copyright 1999-2017 diyAudio
