Practical considerations building LM3886 amp
Old 4th February 2013, 11:17 PM   #31
djoffe is offline djoffe  United States
Earth to Neutral is ideally zero. I wouldn't get too concerned about a few volts...but you have 103 more Volts than a few!
Old 4th February 2013, 11:34 PM   #32
Bloodmist is offline Bloodmist  Romania
Send a message via Yahoo to Bloodmist
Thanx for confirming this. My reckless neighbors and their renovations probably ruined it. It used to be 0 with respect to neutral. Is there a way to fake the earth for the amp?
Old 5th February 2013, 04:27 AM   #33
gootee is offline gootee  United States
What happens if you pull the plug with your ear against the speaker. Does the hum stop instantly or does it continue for a short time?
Old 5th February 2013, 04:43 AM   #34
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
I think your "earth" isn't so any more.
Beyond mere Audio problems, check and repair it at once for your own safety.
Get a registered Electrician to do it or *you* will be liable for any future problem, not kidding.
Now, how come you have 127V in Romania??????
Old 5th February 2013, 06:43 AM   #35
gootee if i pull the plug the hum stops instantly, there remains just the very small hiss that is normal, until the capacitors in the power supply discharge. i noticed also when connecting both transformers the hum is modified. if the primary windings are in phase the hum is still 50Hz just louder than with only the main transformer. if the windings are in anti-phase the hum is not so loud but becomes 100Hz (by "ear-meter").
JMFahey, no, actually it should be 220V. in reality it's 230 on a good day when there is a lot of load. usually it sits at 247V (possibly 250V at night). that's why this is odd. if the earth was still earth, there should be 200-and-something volts between it and the power line. instead it sits about in the middle.
Old 5th February 2013, 02:22 PM   #36
JMFahey's Avatar
OK, now that clears things up.
You do NOT have "220V/neutral" available on your (formerly 220V round pin ) wall socket but you inherited an *old* home power distribution system, once somewhat popular: 2 x 110V out of phase lines, none of which is ground.
What's grounded is the center tap of the 110V+110V distribution transformer which powers a few blocks in your neighbourhood.
I *guess* it was chosen for safety: appliances "see" 220V, but no line is more than 110V away from Earth.
Best of both Worlds ... except it's murder on hum sensitive Audio stuff.
I used to live in a house wired like that
Had to get my own ground using a 3 Meter long Aluminum bar, making a hole in a patio until I found real, black humid Earth.
Oh well.
What you measure is quite reasonable: both voltages add up to about 230V, the new European "de facto" midrange between 220 and 240V standards, and are not symmetrical because of uneven load.
And rising to 250V when unloaded at some times of the day is reasonable too, old overworked transformers and lines have poor regulation.
So, given that you have to live with it, simply remember no power pin is "neutral".
Unless you make a *big* 220V/220V transformer, primary across both "live" lines, secondary ground and hot 220V.
I was about to do the same at my old home, but then moved to a "normal" wired house, so it was not necessary.
Still have the huge transformer core and the heavy duty 5 position switch (since I was getting into it anyway), I was going to add 5 taps to fine tune wall voltage at home.
Old 5th February 2013, 07:15 PM   #37
The main problem is that IT is not the problem... therefor i'm at a loss what might be. I found on the hallway an outlet with normal 220V-0V output and grounding but nothing changed. Since this apartment building is awkwardly wired, at the midpoint between 2 transformers, some outlets are wired to the old transformer, some to the newer one, that was needed only in recent years with more and more appliances drawing power.
There is no noise from the preamp. I've powered it up and it's dead silent regardless of potentiometer position. There's just the everpresent hum from the output stage. I could probably live with it as it's inaudible when say the computer is running (where it gets it's audio anyway) but it's just a mystery to me what could be happening.
Old 5th February 2013, 08:06 PM   #38
JMFahey's Avatar
Well, the scope is your friend
Use it to trace hum or whatever bothers you, step by step.
Old 6th February 2013, 04:11 AM   #39
So then your problem is probably something covered in post 28.
Your signal input and signal ground reference conductors (or paths, or partial paths) might have space between them, allowing them to be an antenna for hum.
Otherwise, maybe your signal reference ground at amplifier input is bouncing. Possibly you connected it too close to rectifier in PSU, instead of after the smoothing caps?
Otherwise, maybe your smoothing caps are not doing a good-enough job and your amp's PSRR is terrible? Do you not have any global negative feedback?
Otherwise, maybe your speaker wires have space between them, and are acting as an antenna.
A picture of the amplifier circuits would be helpful.
Old 6th February 2013, 05:49 PM   #40
while i'm gonna look for a decently priced scope online, i'll try moving the earth point to different places in the ground path. perhaps it would become quiet if i put it on the signal ground instead.
when building it i considered the following layout i found on the net (seems very revealing):
Otherwise the schematic remains pretty much as previously posted by me, just the LM3886 now uses split power supply.
there could be a potential problem indeed that cables to the output connector pass close to the main transformer. i can imagine how signal induced in the output cable would go to the LM's input through the feedback resistor. if all else fails i'll dislodge the connector and place it elsewhere.
Practical considerations building LM3886 ampHide this!Advertise here!
Measuring speakers in-room. Practical considerations. chuyler1 Full Range 38 2nd September 2011 08:37 PM
Considerations in enclosure-building for full range drivers Taterworks Full Range 2 23rd April 2008 06:00 PM
Considerations for building a TWW 2-Way System plamalice Multi-Way 10 8th December 2006 06:31 PM
LM3886 / LM3875 supply voltage considerations breez Chip Amps 7 22nd January 2005 05:22 PM
