diyAudio
diyAudio (http://www.diyaudio.com/forums/index.php)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   gainclone 5.1 big humm trouble (http://www.diyaudio.com/forums/chip-amps/228475-gainclone-5-1-humm-trouble.html)
stephanegagne 23rd January 2013 03:17 PM
HI !
I build 5 channel gainclone with lm4780.
I use 3 independent PSU module with the same 700VA toroidal.
(all my test with PSU is okay)
I build 3 independent AMP module
my setup is :
1x LM4780 for front L-R
1x LM4780 for surround L-R
1x LM4780 for center channel
(all 3 module have same test result and work very well independently)
but when I plug it in the same 7.1 preout OUFFF ! big hummm noise !
I unplug the center channel and the noise stop .
I read 4V between the RCA INPUT ground of each 3 module ?!
By the way, the lm4780 is not isolated to the heatsink, but each amp module have independent heatsink isolated by wood part. (this is a problem?)
Anybody have tips to help me to find solution ?
thanks!
Stephane
Puffin 23rd January 2013 05:51 PM
Probably.
pacificblue 23rd January 2013 06:19 PM
Schematic? Photos?
Resources saved on this page: MySQL 18.75%
