Shorted input...
Shorted input...
Old 24th January 2013, 06:33 AM   #11
Mooly's Avatar
Shorted input...
Thanks for the update. Good job it was only a test speaker that fried.
Old 24th January 2013, 12:46 PM   #12
iggy111 is offline iggy111  Croatia
@johnr66 - well I've seen more than one implementation of this ground lifting by expert members here, so I wanted to try for myself, though I would have to test for any audible advantages - reducing noise would presumably be one of them.
@Redshift187 - so if I hook up a Velleman K4700 speaker protection unit, would that save me from using Cin and Ci?
Now my goal is to squeeze the best possible sound from the chip, and I think we all agree that "no Cin is the best Cin", apart from expensive Mundorfs and such. Right?
If you take into consideration that I actually use only one source at a time, and always measure for output DC, I think it puts me in kind of safe spot, and alows me to get the best sound.
I'm well aware that this is by far NOT the best practice of building amps, and that turning the source component on or off WHILE the amp is on - my speakers would probably die, at least after a few dozen times, because for example I measured DC of more than 4v on output when powering my portable mp3 player hooked to the amp...
Old 24th January 2013, 01:02 PM   #13
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
C'mon, be serious !!!
You worry about the sound degradation a capacitor may introduce and then listen to
portable mp3 player
Old 24th January 2013, 01:11 PM   #14
Mooly's Avatar
Shorted input...
Many portable players need a low value load resistor (circa 33ohms) to load the class D output stage correctly, something that is often overlooked.
Old 24th January 2013, 02:00 PM   #15
I used that mp3 player while testing for DC problems, cause I know it puts out a lot of DC while being powered on and off...
I use Rotel RCD-1072 and my PC with a EMU1212 soundcard for listening music.
Old 24th January 2013, 03:35 PM   #16
johnr66 is offline johnr66  United States
I wish one of the experts would explain it. Why not return the output side to ground through a .22 ohm resistor as well? (makes as little sense to me) Its as if they are afraid to return the signal to ground when it has to flow there anyway.
There is a lot of audio wizardry here, but also a lot of audio foolery such as:
Circuits with missing parts that compromise reliability and safety.
Added parts of questionable purpose.
Pushing parts beyond datasheet absolute maximum ratings.
Buying on price only. You often get stuck with counterfeit parts. They might work at first, but can fail eventually.
Old 24th January 2013, 04:10 PM   #17
Can't help you with all those questions...
Shorted input...Hide this!Advertise here!
How do I know a transformer is shorted? chipper Car Audio 8 2nd April 2012 08:56 PM
Shorted EL34 ? DonDiego Tubes / Valves 3 21st October 2010 10:25 PM
shorted out deck??? new one Car Audio 6 22nd June 2008 01:09 PM
Pearl shorted...please help me out of this! h_a Pass Labs 28 4th June 2007 02:55 PM
Help with Shorted Xformer lgreen Parts 1 27th June 2004 04:58 PM
