LM1876T diy HiFi amplifier build, questions, PCB, components, so on..
Old 22nd January 2013, 07:39 AM   #1
Mihkus is offline Mihkus  Estonia
Mihkus's Avatar
Default LM1876T diy HiFi amplifier build, questions, PCB, components, so on..
Heya everyone, yesterday i ordered single LM1876T chip to change TDA7265 wihich sounds terrible, speakers are rubbish too Defender mk35 somekind of Hi-Fi they say...
Well i removed the preamp JRC4558 known as worst opamp known to man but great for guitar applications.
Now i designed single sided PCB with fillet plane ground...
Now sure if everything is okay, well... PINout taked from datasheet and also SCH
they say LM1876B pinout is shown...
Heres the PCB ive designed, may have lots of mistakes...
Non inverting or negative - input caps 2,5mm ones on board are hooked with ground.
Also there are few jumpers one on input other on the output side.
free image hosting
Old 22nd January 2013, 08:32 AM   #2
pra3718 is offline pra3718  India
How about star grounding ? If mute=not connected then take care about pop. You don't need Rin ? Is it possible to move Cs (electrolytic + ceramic) to power pins ?
Old 22nd January 2013, 08:44 AM   #3
Mihkus's Avatar
Yeah, star grounding may be best solution, right now i have thin rail going to pin 10...
We can move everytihing on board, im new to this PCB designing thingy, well i have made few amps, DAC's, preamps and so on but making PCB with minimal amount of space and without knowing what the heck is the difference between LM1876T and B
Took pinout from B type...
Old 22nd January 2013, 08:56 AM   #4
LM1876T = non-isolation package.
Is that lm1876b ?
Old 22nd January 2013, 09:17 AM   #5
Mihkus's Avatar
This is LM1876T i was sure it not sealed.
What to i need to to with mute function?
Just leave it?
Old 22nd January 2013, 10:30 AM   #6
Mihkus's Avatar
Now, still like fillet...
My own last result, may be totally wrong...
upload foto
Old 22nd January 2013, 10:42 AM   #7
The two film caps on the +ve & -ve rails are in the wrong place.
They should be on or at the Power Pins of the Chip.
regards Andrew T.
Old 22nd January 2013, 12:17 PM   #8
Mihkus's Avatar
Well, how about that?
online photo sharing
Yellow lines on pads are jumpers..
Old 22nd January 2013, 12:32 PM   #9
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Using a groundfill means you'll get crap sound because the noise currents from the input socket are going via the caps (C1, C? unmarked) to gnd. Shared ground impedances suck worse than TDA7265s for sound. I get fairly decent sound out of the bass/mid driven by my TDA7265s, the tweeter sound though is very, very dull.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 22nd January 2013, 04:23 PM   #10
Mihkus's Avatar
Then i should use 2 separated grounds input ground and supply ground?
LM1876T diy HiFi amplifier build, questions, PCB, components, so on..Hide this!Advertise here!
Scheme to build a power amplifier on these components alexkmp3 Solid State 1 19th December 2012 09:28 PM
first diy speaker build, tri tix vented. couple questions rockironwebb Multi-Way 2 15th June 2012 11:53 AM
KTA-HiFi ST-70 pcb or marantz 8b. HiFi build iglehart332 Tubes / Valves 18 18th March 2011 03:19 AM
Lm1876t jackinnj Swap Meet 0 14th December 2009 07:16 PM
Where can I purchase high end components to build a DIY POWERED sub? bottgers Subwoofers 21 20th September 2004 07:38 PM
