2x30V,225VA toroid in stock... what amp?
Old 18th January 2013, 10:22 AM   #1
child1 is offline child1  Denmark
Default 2x30V,225VA toroid in stock... what amp?
Hi all!
I have a toroid (225VA,2x30V) in stock, and I want to build an subwoofer amplifier, but all the chipamps i can find is not able to withstand +/- 42(43)V supply....
Any thoughts on which amp i could build that could use this x-former?
Grats!
Mads, Denmark
Old 18th January 2013, 10:35 AM   #2
Mooly's Avatar
LM3886 (at its safe limit really) and the TDA 7293 come to mind. Its a high rail voltage though and lower is often better for reliability. Your better getting a more suitable transformer tbh
Old 18th January 2013, 10:44 AM   #3
aadrian is offline aadrian
You can also use TDA7294 without any problems
Old 18th January 2013, 11:04 AM   #4
Mooly's Avatar
The TDA 7294 is a rated 100 volts max under no signal conditions. For an 8 ohm load the data sheet specifies 80 volts total as an absolute maximum.
Old 18th January 2013, 05:07 PM   #5
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
Go discrete for reliable 150W/4r or thereabouts.
An LM3886 won't cut it, and the TDA7294 is *just* on the edge, for an 8 ohms load.
I'm not a fan *at all* of parallel chipamps.
A subwoofer amp is an "easy" one.
Who needs 0.0001% distortion/high slew rate/500 KHz bandwith/class A/whatever there?
Any simple raw power amp will do.
Tons of projects, even here at DIY.
Old 18th January 2013, 05:29 PM   #6
Tekko is offline Tekko
Banned
TDA7293 parallel will work with this transformer.
Old 19th January 2013, 03:29 AM   #7
JMFahey's Avatar
The point of life is to build atleast one audio amplifier before you die.
Then I should have died 10000 times by now
2x30V,225VA toroid in stock... what amp?Hide this!Advertise here!
FS: 2 Toroid 1000VA dual 2x30V alexcd Swap Meet 16 3rd December 2012 03:06 PM
FS:Two toroid 225VA 2x26V transformers supernet Swap Meet 5 23rd August 2011 12:14 PM
FS: 225VA 2x18v toroid UK dhole Swap Meet 1 13th May 2009 08:04 AM
Swap: 225VA 2x18v for 2x30v dhole Swap Meet 4 6th May 2009 06:26 PM
WTB: Stock or near stock ART DI/O buzzinghive Swap Meet 0 16th March 2007 09:06 AM
Copyright ©1999-2017 diyAudio
