Old 15th January 2013, 09:15 AM   #1
Default 2.1 active crossover + amp build
Hi all.
I've started working on an 2.1 amplifier. The idea is to have active crossovers for all the speakers, summing for the sub. There will be a total of 5 amplifiers (tda7294 i think): 2 for left (mid + high), 2 for right (mid + right), 1 for sub.
The basic idea was to have all of these built on the same PCB with a whole ground plane for all the pieces (crossovers and amps). I will post pictures with schematics & pcb's as I move forward.
Questions from the start:
1. Is it a good idea to have them all on the same PCB or should I try to have them like modules?
2. Should I first low pass the inputs and them sum them, or sum them then low pass the signal?
I am sure I'll have lots of questions during the process but hopefully I'll be able to finish this up nicely.
Thanks,
Adrian
Old 15th January 2013, 09:44 AM   #2
just another
wintermute's Avatar
On 2 (without speaking from experience) I would say it would be better to sum them after low passing, simply because it will give you more isolation from your high pass signal (ie less chance of your summing causing stereo crosstalk on your high pass stereo channels. Of course the downside is you then need to implement stereo low pass circuits...
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 15th January 2013, 11:39 AM   #3
Use an MFB low pass filter.
It is inverting and can accept two inputs.
It both filters AND adds.
Old 18th January 2013, 12:35 AM   #4
gman76 is offline gman76  United States
adrian, sounds interesting, sorta like what I was thinking about doing. By 2.1, do you mean you'll have an amp for the sub? I thought most subs these days have a plate amp. And you have 2-way bookshelf speakers? (a mid/bass and a tweeter?) I have a few different 2-way speakers to target. I'm thinking of designing a plate amp that has active filters with adjustable xo freq and drives a 50W low freq and 20W high freq. Not sure how fancy I was to get with filter alignments and time delay correction. I've been reading Rod Elliot's articles about passive vs active crossovers, and it all makes a lot of sense (how passive have many shortcomings and cause a lot of problems if not designed properly).
Old 18th January 2013, 06:54 AM   #5
yes gman, I'll have 2 2way bookshelf (midbass + tweeter) and a sub. I'll use the sub a little higher then regular (somewhere around 200Hz) since it's hard to get a good midbass driver without a lot of money but that shouldn't be a problem.
I'll post pictures of the circuit and the PCB design as it's now soon.
Recommend an active crossover (self build) Zoodle Multi-Way 12 9th July 2012 06:14 AM
FS: ATC Active Discrete Amp & Crossover Boards hisense Swap Meet 5 4th June 2011 10:13 PM
How to build DIY 8th order 48db active crossover?? Hybrid fourdoor Multi-Way 6 28th October 2005 06:59 AM
Which economy active crossover to build? kimbo Multi-Way 23 1st May 2005 12:26 AM
Help me build a semi-active crossover officeboy Parts 2 27th January 2004 06:18 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
