TDA7293 datasheet
TDA7293 datasheet
Old 31st January 2013, 07:19 PM   #81
Kitax is offline Kitax  Latvia
i was actually aiming for a lower voltage... more like this... buffer accumulator (3.6V)
Buferakumulators 3.6V/60mAh, 3cells - Buferakumulatori, lod?jamie - Tabletes veida akumulatori - Akumulatori - ENER?IJA - Katalogs - Argus Radiodeta?u Tirdzniec?ba
Old 31st January 2013, 07:39 PM   #82
Mooly's Avatar
TDA7293 datasheet
That might be too low.
You need to first of all determine a suitable relay is available and design the whole circuit around that.
I think you can get 2.4 volt versions of that style of battery. Two in series would be fine.
Old 31st January 2013, 07:52 PM   #84
well i can put this one, with another 1.2V battery and have the same effect, only cheaper...
Old 31st January 2013, 07:57 PM   #85
Mooly's Avatar
TDA7293 datasheet
You could... neater if all the same though.
Old 31st January 2013, 08:00 PM   #86
i know, but i have a limited budget
Would this one work?
https://www1.elfa.se/data1/wwwroot/a...S40_Data_E.pdf
Old 31st January 2013, 08:05 PM   #87
Mooly's Avatar
TDA7293 datasheet
They look OK.
TDA7293 datasheetHide this!Advertise here!
need help with TDA7293 weatherlight Chip Amps 21 23rd November 2013 10:49 AM
Tda7293 lasstss Chip Amps 2 14th December 2004 05:36 AM
Where can I get a TDA7293??? mfish0305 Solid State 2 18th January 2004 04:19 AM
Tda7293 chengtaw Solid State 0 18th April 2002 02:19 PM
