TDA7293 datasheet
TDA7293 datasheet
Old 30th January 2013, 06:17 PM   #71
Kitax is offline Kitax  Latvia
oh... i just dont want to use a 12 v battery, because of the price...
Old 30th January 2013, 06:22 PM   #72
Mooly's Avatar
TDA7293 datasheet
Use a little PP3 nicad or whatever you can get. Or AA or AAA's.
Old 30th January 2013, 06:35 PM   #73
dont i need 12 volts?
Old 30th January 2013, 06:39 PM   #74
Mooly's Avatar
TDA7293 datasheet
Most 12 volt relays will pull in at far less than 12 volts.
Old 30th January 2013, 06:40 PM   #75
oh... that explains a lot ^^
Old 30th January 2013, 06:42 PM   #76
Mooly's Avatar
TDA7293 datasheet
You could use a 6 volt relay too and 4 AA's. Just adjust the values to suit.
As long as the normal (amp on) relay voltage is arranged to be higher than the battery by a couple of volts then the battery will charge correctly.
Old 31st January 2013, 12:40 PM   #77
you said: "Most 12 volt relays will pull in at far less than 12 volts."
how much less are we talking about?
heavent really delt with relays...
Old 31st January 2013, 03:47 PM   #78
Mooly's Avatar
TDA7293 datasheet
I just tried it for real on a 12 volt relay and it pulls in reliably at 6.7 volts. Every relay will be different but you get the idea.
Old 31st January 2013, 04:16 PM   #79
mmm... so if i take a 6V relay, i could count on about 3-4V?
Old 31st January 2013, 04:42 PM   #80
Mooly's Avatar
TDA7293 datasheet
Yes, a 6 volt relay would pull in with 4 AAA batteries which would give around 5v volts when fully charged. The resistor values would be chosen to give say 6.5 or 7 volts across the relay when the amp was running.
TDA7293 datasheetHide this!Advertise here!
need help with TDA7293 weatherlight Chip Amps 21 23rd November 2013 09:49 AM
Tda7293 lasstss Chip Amps 2 14th December 2004 04:36 AM
Where can I get a TDA7293??? mfish0305 Solid State 2 18th January 2004 03:19 AM
Tda7293 chengtaw Solid State 0 18th April 2002 01:19 PM
