TDA7293 datasheet
TDA7293 datasheet
Old 29th January 2013, 06:14 AM   #61
Mooly's Avatar
TDA7293 datasheet
I still don't see it tbh
Are you trying to switch the mains here or the DC side ? How does the cap charge in the right hand diagram
Old 29th January 2013, 11:41 AM   #62
Kitax is offline Kitax  Latvia
yeah well i need another swich for the cap to charge... it would take too much swiches actually... :S
Old 29th January 2013, 11:43 AM   #63
Mooly's Avatar
TDA7293 datasheet
Use the nicad battery idea... easy and simple.
Old 29th January 2013, 06:06 PM   #64
ok...
you mean like this, right?
p.s.
the polarity of battery isnt right...
Old 29th January 2013, 06:51 PM   #65
Mooly's Avatar
TDA7293 datasheet
Something like this. The 9 volt nicad starts the relay. When the amp rail takes over, that supply keeps the relay energised.
Choose R1 to give required trickle charge current.
Choose R2 to give 12 volts across the relay.
Old 30th January 2013, 08:18 AM   #66
oh ok... the diodes on the top if ment for the battery not to discharge, right? and the zener, for it to not overcharge right?
Old 30th January 2013, 10:54 AM   #67
Mooly's Avatar
TDA7293 datasheet
That's it. The zener clamps the battery voltage. Set the charge rate low, something like 30/C. Diodes would all be 1N4004 or similar
Old 30th January 2013, 12:28 PM   #68
the problem is that if i use a 12 volt battery... well its pretty expensive for the power switch
Old 30th January 2013, 12:46 PM   #69
http://sharp-world.com/products/devi...pr36mf51_e.pdf
can i use this one?
Old 30th January 2013, 06:06 PM   #70
Mooly's Avatar
TDA7293 datasheet
There's a bit of confusion here
I thought we were keeping it simple and using a normal mechanical relay. A 12 volt relay coil with the relay switching 240 volts mains. Using an opto triac is a whole different thing. The triac would have to control a larger power triac to handle the switch on surge and current requirements.
TDA7293 datasheetHide this!Advertise here!
need help with TDA7293 weatherlight Chip Amps 21 23rd November 2013 09:49 AM
Tda7293 lasstss Chip Amps 2 14th December 2004 04:36 AM
Where can I get a TDA7293??? mfish0305 Solid State 2 18th January 2004 03:19 AM
Tda7293 chengtaw Solid State 0 18th April 2002 01:19 PM
