Opamp challenge
Opamp challenge
Closed Thread
Old 20th January 2013, 04:33 PM   #51
R.I.P.
There is nothing unconstructive about saying "somebody has reinvented
the wheel", in this case "bootstrapping", if the circuit works as claimed,
or they don't have anything if it doesn't work as claimed.
The claims about distortion appear to be
"guilding the lily" and don't make any sense.
The only way to lower the high pass frequency is to make the apparent
input impedance higher, and to do that you need to modulate the other
side of the input resistor with a signal similar to the input signal. This
is a doddle with a unity gain stage, with a bootstrap capacitor from the
output. If you have gain then the unity gain point is the inverting input,
and you bootstrap from that point, noting it has higher source impedance
than directly from the output.
What is unconstructive is the obfuscation about something that either
works and is very old, or its "new" and it doesn't work as claimed.
There is a phenomenal arrogance in stating you have come up with
a "new" simple circuit topology when that likelihood is very near zero.
rgds, sreten.
Unity gain bootstrap for a low low pass with a small capacitor :
How to modify the original circuit should be obvious.
Old 20th January 2013, 05:08 PM   #52
R.I.P.
Should read :
Unity gain bootstrap for a low high pass with a small capacitor :
rgds, sreten.
Old 20th January 2013, 05:46 PM   #53
diegomj1973 is offline diegomj1973  Argentina
diegomj1973's Avatar
sreten:
My circuit does not look anything like what you have presented.
There are many more variants. Not everything always leads to this bootstrapping technique (which may serve to increase the impedance seen by the signal source) ...
Do you think that this bootstrapping technique is the only way to reach the goal?. The technical horizon is wider than you think.
As an example: Mooly uploaded a proposal that does not necessarily use the bootstrapping technique (and was very close to the targets).
Anyway, thanks for your effort (that's more positive for the whole forum).
regards
Old 20th January 2013, 06:09 PM   #54
Mooly's Avatar
Opamp challenge
So we have to think outside the box
I am still intrigued
Old 20th January 2013, 06:12 PM   #55
R.I.P.
The level of pretension here is out of control.
Put up or shut up. Not many people get to redefine
how circuits should be designed and you don't
remotely strike me as someone that could.
rgds, sreten.
Old 21st January 2013, 12:49 PM   #56
sreten:
Here there is no pretense of anything: I have invited you to try to get a particular result in a given circuit, given certain conditions.
Anyone who wants to participate, explains his idea and then we can discuss it. This is very simple.
Also, I do not pretend to redefine the way each of you design their circuits: I only expose the pros and cons of each alternative (uploaded by forum users) when compared with the option that I use, to arrive at the desired results.
If someone finds out what I'm using, congratulations.
If not discovered, also serves: you can always salvage something positive.
regards
Old 21st January 2013, 02:45 PM   #57
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
SRETEN, I simply don't think that DiegoMJ has any idea how ivory-tower pretentious he's being. I've noted this in other forums, and with people in daily life. They have extraordinary faith in their magnificent achievement, and through scheming and obfuscation, through come-along and super-authoritarian pseudo-mentorship, challenge all those whom they get in audience, to invent or recreate something they barely have the ability to concretely describe. DiegoMJ is such a character, it is clear. Has probably desired his entire life to be so inscrutably superior that all people around him are not peers but subjects.
Paraphrasing his pretention: "I have done it! I challenge you to take this simple looking thing, and using no other components, improve upon it hugely. The results you come up with, I will grade for their authenticity, and I'll keep providing feedback while y'all with my blindfolds on, keep searching with your hands out. Its fun! Its educational! Keep at it me hearties! You're so close to the bucket 'o' gold. (Moves the bucket again...)"
Yes, pretention, stultifying self-absorbed ego, and if anyone unhappy with this analysis cares to remember: No damned diagram Its patent-pending, you know.
Your analysis of impedance-lifting is exactly correct. There are no other solutions that don't topologically rearrange to impedance multiplication if the frequency-response of an input (or other signal-path) capacitor is to be mitigated. Period.
GoatGuy
Old 21st January 2013, 03:20 PM   #58
Mooly's Avatar
Opamp challenge
I have a question
The circuit in post 1 could be duplicated (i.e. two built) and then be fed from a "normal" source such as a CD player etc. Both circuits would in that case operate independently of course.
Can your "new" circuit like-wise be duplicated in the same way and two the "channels" operate independently when fed from a "common" source.
Just a wonderin
Old 21st January 2013, 06:19 PM   #59
magdrop is offline magdrop  United States
This is a great challenge; it's very easy to understand yet very difficult to solve.
Obviously, some folks don't respond well to being presented with a challenge. This turns out to be much more entertaining than the puzzle itself.
Great thread, and great OP!
Old 21st January 2013, 07:30 PM   #60
R.I.P.
Really ? How do you know that ? You'd have to know the supposed
solution and your stuff to be any judge of the merits of this thread.
rgds, sreten.
I've already posted how you usually would do it, and it works.
Closed Thread
Opamp challengeHide this!Advertise here!
Here's a challenge.... Meshuganah Solid State 42 16th November 2011 01:59 AM
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
