Opamp challenge
Opamp challenge
Closed Thread
Old 15th January 2013, 08:07 PM   #21
diegomj1973 is offline diegomj1973  Argentina
diegomj1973's Avatar
JMFahey:
The circuit presented by you does not seem in the least to mine.
Also, if you take the trouble to simulate or measure will notice that this circuit does not meet even close to what I can get with my design.
Believe me, I understand you perfectly in the fact that you may be wary of something new.
The blue curve corresponds to what you have kindly uploaded.
Opamp challenge-comparative-jpg
regards
Old 15th January 2013, 09:54 PM   #22
I used the 741 simply to represent an audio amplifier. But you can extend the application to any similar topology (TL071, TL081, etc or even discrete, like the one I'm using). This can be for small signal or power, too.
Laboratory measurements were made with a simple and inexpensive TL081CP.
I know I'm risking a lot in a forum as prestigious as this. And was not the only one in which I presented this challenge. This is my choice for very personal things (which may be irrelevant to the forum, but it is very important to me).
With my greatest respect
Old 16th January 2013, 07:11 AM   #23
Mooly's Avatar
Opamp challenge
I'm intrigued by what you feel you have come up with. I haven't been able to replicate all you claim in particular keeping the voltage gain at around +3.9
By AC coupling the output via the 10 uf you can then use the 10K as a ground reference.......
Have you tested your circuit with non sinusoidal waveforms and deemed it acceptable ?
Old 16th January 2013, 06:38 PM   #24
pacificblue is offline pacificblue  Germany
Why is it prohibited to skip components? Wouldn't the possibility to achieve a similar result with less components be an inprovement?
If you can live with inverted phase, you can tidy up the following schematic later. I.e. skip the 100 n cap, use 2,4 k instead of 2 x 1,2 k, 9,31 k or 9,53 k instead of 2 x 4,7 k.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 16th January 2013, 06:54 PM   #25
TNT is offline TNT  Sweden
Prior art killed the cat?
Old 16th January 2013, 07:00 PM   #26
Mooly's Avatar
Opamp challenge
I came up with this as per original requirements although I suspect it isn't what he is after... and its just a bit of fun
AC coupled input, Yes
Similar HF response, Yes
Voltage gain of 3.92, Yes
Similar input impedance, Yes
Output developed across the 10K, Yes
Same components used, Yes. All the components in the original are used.
No real offset issue, Yes. The 741 isn't perfect here anyway.
Non inverting of overall phase, Yes
Old 16th January 2013, 07:44 PM   #27
GoatGuy is offline GoatGuy  United States
GoatGuy's Avatar
I think the poster (original) is suffering from delusions and is further insufferably pretentious. A "design" without a "purpose", or with a "secret purpose", and an ill-defined "challenge" ... is delusional and pretentious.
"Power - makes others strive to want something that is kept unachievable" - some wag in 1949.
GoatGuy
Old 17th January 2013, 12:56 AM   #28
Pacificblue:
Close, but suffers three important things:
1) The magnitude, while not as is (it is very close), but the phase is inverted. This could be a minor problem but ...
2) The offset problems have not been considered. This stage can cause problems, if the gain becomes important (to make it more generic).
3) There is an improvement that is not served by that configuration, but I can not disclose yet, because it would give guidelines to find the answer.
regards
PD: I did not say I was forbidden to skip components.
Opamp challenge-comparative-2-jpg
Old 17th January 2013, 11:41 AM   #29
Mooly's Avatar
Opamp challenge
Originally Posted by diegomj1973 View Post
To accomplish this, one has to use the same components shown in Scheme A (referring to quantity, type and value). Not allowed to remove or add components as those shown in Scheme A (you must use the same components, to achieve the objective of this challenge).
Pacificblue:
Please clarify In the first post you say all components must be used (not allowed to remove...) and the later post implies you can skip using some parts.
Old 17th January 2013, 04:01 PM   #30
Remove: use fewer components that have been shown. Example: if the original scheme employs 8 => implies having used less than 8.
Add: use more components that have been shown. Example: if the original scheme employs 8 => implies having employed more than 8.
There are no restrictions on the order of connection between components. There is complete freedom to connect as you wish.
PD: In the scheme proposed by Pacificblue the input impedance of the circuit is not around 5K9 (in the passband).
regards
Closed Thread
Opamp challengeHide this!Advertise here!
Here's a challenge.... Meshuganah Solid State 42 16th November 2011 01:59 AM
Here is a Challenge latala Solid State 41 12th May 2011 01:13 AM
Single supply opamp - unequal rail voltage and opamp selection Hans L Parts 8 19th February 2006 02:15 PM
a challenge --or I need help lawrence99 Car Audio 0 9th March 2005 04:44 AM
The challenge ! thylantyr Solid State 51 24th July 2003 08:41 PM
