diyAudio
diyAudio (http://www.diyaudio.com/forums/)
-   Chip Amps (http://www.diyaudio.com/forums/chip-amps/)
-   -   LM1875 Trebles Modifications (http://www.diyaudio.com/forums/chip-amps/227751-lm1875-trebles-modifications.html)
Joseph1 14th January 2013 12:10 AM
1 Attachment(s)
I have built my own 2.1 subwoofer system using 3 LM1875.It is a locally available kit.Also I corrected some mistakes on it.
The design works nicely.The only problem is the two satellite amps trebles is not enough.
I uploaded the schematic by tracing the KIT.You can go through the red covered area.
What modifications to be done to gain more trebles.
hitsware 14th January 2013 01:15 AM
remove R24 and C14
attach input to C15 .........
Joseph1 14th January 2013 01:22 AM
1 Attachment(s)
Hi thanks for the help.
I corrected the mistake.Here is the corrected one :)
Joseph1 14th January 2013 10:41 AM
Hi I removed the R24 and C14 & checked the system.The gain increased much.
I mean from the two satellites its coming too much sound comparing to sub amp,so when hearing I cannot hear much bass from the sub amp.
Is there any gain ratio between satellites & sub amp in 2.1 systems?
Here is my system gains
Satellite amp Left = 20
Satellite amp Right = 20
Sub preamp TL072 gain = 12
Sub Amp = 20
When listening to music I always put BASS level in subamp to half way mark in linear potentiometer.
basi 14th January 2013 10:44 AM
Hi!!!Reduce R26 to 24k.
Joseph1 14th January 2013 11:01 AM
Hi I increased the value of R27 to 3.3K so the new gain will be -11.8.
Now the two satellites have -11.8 each.Now I can hear balanced sound.
But still the sub amp has these gains.
Sub Amp = 20
Is it ok?
Copyright 1999-2017 diyAudio
