| Chip Amps Amplifiers based on integrated circuits |
#61 |
It's because the lm3886 pins aren't the same spacing as the board I'm using. But if i turn the chip 45 degrees, they fit perfectly (fortunately!). So i just cut off that side. Actually worked out well for part placement anyway.
I have one amp board almost completed. Once I get that one done, I'll test it to make sure all is well before building the second. Need to go to the store to get parts for the light bulb tester. |
#62 |
After a very busy week, I finally had a chance to test the first channel and it appears to be a success! It seems to work perfectly so far. It's amazingly quiet, even with messy test wiring/grounding. I can only hear the faintest hiss from the amp with my ear right against the speaker. On to the second channel!
Again, thanks to all who helped me out on this, I'm excited to get this completed. |
#63 | |
Oh, and I'm getting only -1.6mv of dc offset on the output. That seems about right, no? |
#64 | |
Anyhow, congrats are in order for getting at least half of it working! good luck with the 2nd channel.....
#65 |
I am personaly collecting the bits for a similar project; but 3 way tone control and probably 6 inputs or 5 and phono.
#66 | |
I did get the second channel built yesterday, but when I tested it, I was getting some strange DC offset readings. As the amp powers on, there's a small spike in DC offset, but it settles down to 0v. Then when powering off, it remains very low for about 3 or 4 seconds, then suddenly jumps up to -4v. It slowly goes down from there. It was built pretty much identical to the first channel, and I've triple checked the wiring. So I'm a bit confused as to why this is happening. While powered on and 0v dc offset, I hooked up a speaker and it sounds great, like the other board. But I haven't dared leave it plugged in when powering off lest the speaker get hit with -4v. Any thoughts on what could suddenly cause such a spike of DC offset on power off, but it reads 0v while powered on? I immediately started looking at the 3886's mute function (Rm and Cm on my schematic), but everything appears correct and matches the other (now dead) channel. So I'm confused. |
#67 |
The offset might not be so bad with a load (try it with a 10 ohm or something). Amplifiers of all kinds can do strange things as the rails collapse and the real answer is always to provide a simple switched speaker delay, 4 volts won't harm the speaker but is would spoil the "user experience" of such an amplifier. Try it with the dummy load.
For the channel that saw reversed supply, I wouldn't use the LM3886 whether or not it appeared functional. It's just not worth the risk later down the line.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#68 |
I was going to post answer when I got into work (typing on my mobile on a train is a bit of a hit and miss affair) .... However I see Mooly has replied - with exactly the same answers I'd have given!
However in addition I went to check the datasheet because I had suspicion this device had more than one ground - it doesn't. But, there ARE pins with NC written by them Check there are no shorts (solder or copper whisks) to ANY of these pins sometimes NC does not necessarily mean "no INTERNAL connection" and you can get odd behaviour if they ARE connected to anything..... Last edited by blu_glo; 18th February 2013 at 06:42 AM. Reason: something else occurred to me.... |
#69 |
Great minds think alike
#70 |
| Tone control | argonrepublic | Solid State | 11 | 13th November 2011 01:32 AM |
| To tone control or not to... | dagerman | Tubes / Valves | 12 | 27th June 2011 06:15 AM |
| Tone control | argonrepublic | Solid State | 0 | 28th February 2010 12:12 AM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| Tone Control for my GC | aditaquil | Chip Amps | 5 | 6th January 2005 11:39 PM |
| Page generated in 0.29307 seconds (100.00% PHP - 0% MySQL) with 10 queries |
