| Chip Amps Amplifiers based on integrated circuits |
#41 | |
Pin 10 is the one that must be referenced to ground.Pin 9 may or may not be according to the design requirements. If it is DC coupled (no 33uf) then the amp will have a large(r) DC offset than needed and will "amplify" its own internal offsets as they drift. AC coupling returns the gain to 1 at DC and minimises these issues. The input bias currents (the tiny DC current that flows out of or in to the input pins) should be equal for both inputs. Or more correctly the volt drop developed by those currents across the input and feedback resistors should be equal. Keeping the resistor values equal achieves that. So 20K feedback resistor and 20K input bias resistor. For example, 0.1 ma bias current (just to illustrate, it would never be this high) would develop 0.0001 * 20K or 2 volts at pin 10. It would also develop the same voltage at pin 9 with the bias current flowing in the 20K feedback resistor. Same voltage on the inputs means no difference in voltage between the inputs. So the output is zero volts DC... all good. Now change either 20K to some other value, say 30K. We now have 0.0001 * 30K which gives 3 volts on the appropriate pin. Result... a DC offset error, one that is made worse if the feedback is also DC coupled because the chip can amplify that error. So keep the DC currents equal by keeping Rin and Rf equal and AC coupling the feedback return.
------------------------------------------------------- A simulation free zone. Design it, build it, test it. |
#42 |
Thanks for tidying that up, I forgot to finnish saying where that resistor should go; and yes I agree it should remain same value as the feedback resistor!
#43 |
All he has to do is go and build it now
#44 | |
thanks! |
#45 |
#46 |
#47 |
Don't be afraid of caps in the signal line
![]() It should look something like this... I've left the bypass as it was. The 470K's define the DC conditions on the caps when they could otherwise be "floating". It stops load thumps and bangs when switching and connecting.
#48 |
Thanks a lot. Working on making the changes now.
Not afraid, just cautious based on what I've read, but of course I should always be cautious of what I read... Caps seem to be a hot topic for some. I'm learning by reading/experimenting, not by any actual electrical training... Since the values are so high, they'll need to be electrolytic, would there be any benefit to a poly cap bypass on the electrolytics in the signal path? I built the Millet Starving Student Hybrid headphone amp and used a poly bypass on the output capacitors and did notice a difference, maybe that's a different case though. Nichicon KZ or FG a fine choice here? BTW, here's my MSSH I built last year. Other than a cmoy, this was my first real amp project. I'm pretty happy with how it turned out. I use it on my desk at work most of the time. Funny how many people are somewhat afraid of glowing tubes for some reason... |
#49 |
That looks nice
Excellent job.The big thing to concentrate on with the chip amp is the layout and grounding of it all. Did I post a link to this ? 3 stage LIN topology - NFB tappings? you have to get this right.
#50 | |
| Tone control | argonrepublic | Solid State | 11 | 13th November 2011 01:32 AM |
| To tone control or not to... | dagerman | Tubes / Valves | 12 | 27th June 2011 06:15 AM |
| Tone control | argonrepublic | Solid State | 0 | 28th February 2010 12:12 AM |
| i need preamp schematics w/o tone control or volume control | hernanstafe | Parts | 7 | 30th January 2008 03:12 AM |
| Tone Control for my GC | aditaquil | Chip Amps | 5 | 6th January 2005 11:39 PM |
