Whats a GOOD LM3875 chip amp circuit?
Old 14th November 2003, 07:47 PM   #1
matt_uk is offline matt_uk  United Kingdom
Default Whats a GOOD LM3875 chip amp circuit?
Does anyone have any tried and tested circuits for this amp? I like the look of GregCC's 'Ultimate gain-clone' because of it's simplicity, maybe add some DC protection on the output.
In this type of amplifier application does the pot have to be wired the opposite way around to usual, so when the volume is down there is maximum resistance between the line in and chip in?
Also, is it really worth going for super components (as there aren't many), high audiograde pot, caps? How critical is the PSU design? How much VA rating for the transformer (230V AC)?
Looking at the 'Ultimate Gain-clone' design the max gain is 22 (i think!)? so with an input voltage of 1.5-2V, so should I be looking at around 40V supply voltage?
Matt
Old 14th November 2003, 07:50 PM   #2
JOE DIRT® is offline JOE DIRT®  Canada
JOE DIRT®'s Avatar
Matt...this topic is explained very well on the forum...take a look
DIRT®
Old 14th November 2003, 07:57 PM   #3
forgetting my +/- supply. Can a 2 x 40V transformer be wired into +/- 40V? I'm sure it can but don't know much about PSU design.
Does anyone have a PSU circuit? As I know nothing about bridge rectifiers or anything related to volatages greater than 3.3!
Matt
Old 14th November 2003, 08:11 PM   #4
Peter Daniel is offline Peter Daniel  Canada
Peter Daniel's Avatar
Whats a GOOD LM3875 chip amp circuit? Send a message via AIM to Peter Daniel
Some specific info can be found here http://www.diyaudio.com/forums/showt...921#post261921
Otherwise do search in a Chip Amps forum
www.audiosector.com
“Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC
Old 14th November 2003, 08:12 PM   #5
GregGC is offline GregGC  Canada
One of the many good places to start:
http://home.ca.inter.net/~cfraser/Gainclonehome.htm
http://www.euronet.nl/~mgw/diy/amps/uk_geenkloon_1.html
Check this on general Power supplies, but please pay attention to the 1000uF in the Gainclone case. It's important.
http://www.zero-distortion.com/techn...ly/powersi.htm
Old 14th November 2003, 09:23 PM   #6
theChris is offline theChris
i guess this all depends on how much you want to put into it. i mean in the bare form the chip still works well. some people like the more expensive components and all, but when it comes down to it, they only matter if you can tell a difference. if your putting the speakers in an area with a high noise floor, well...
as for PSU design, remember that your transformer output will be about 50% higher then the ratings, as you are going to get a DC voltage close to the peaks and not close to the RMS value. this means that a +-24V transformer will be closer to +-35V on the output. there are discussions on power supply theory, and there seems to be some indication that a small resistance between the rectifier diodes and the filter caps is beneficail as it forms an RC network and enhances the lowpass filter effect.
if only it could be used for good, not evil...
Whats a GOOD LM3875 chip amp circuit?Hide this!Advertise here!
whats a good diy tube preamp kit merickrc Tubes / Valves 40 28th March 2009 10:24 AM
I'm looking for LM3875 chip??? thomgun_lc Chip Amps 5 3rd January 2006 07:26 AM
Whats a Good 6L6 circuit? hacknet Tubes / Valves 34 25th April 2004 07:31 PM
Good but simple subwoofer chip amp. circuit suggestion Alvin Chip Amps 2 17th January 2004 01:04 PM
Whats a good.. jleaman Multi-Way 6 9th November 2002 04:56 PM
Copyright ©1999-2017 diyAudio
