Couple of Qs about my LM3875 circuit - diyAudio
Old 6th January 2013, 01:06 PM   #1
Robert Kesh's Avatar
Default Couple of Qs about my LM3875 circuit
I'm working on the above. I have no choice over the supply, and have a couple of questions about the single supply circuit, which is pretty much straight from the datasheet, with changes to nfb resistors, and a minor change to the input bias resistor (due to not having a 75k).
The application isn't hi-fi, but obviously I want to get the best circuit possible given the constraints. A low bass response is not necessary.
1. There's no decoupling cap on V/2 on the datasheet. Pretty much every other single supply V/2 resistor network I've seen has one parallel to the resistor I've labelled Ra. Should I use one?
2. I'm thinking the input cap Ci's high pass calculation should take R as 68k + 100k||100k, ie 118k. Is this correct? Does the input pot (which may be changed) or the previous stage's output impedance play any part?
3. I understand it is good to have as little AC voltage across Cf and the output cap as possible. I have no control over choice of output cap, so will be selecting Ci on this basis. Given a lack of AC voltage I'm thinking the 50V rating on the output cap is OK, even though the signal could swing higher, as this will just pass through so long as I set the input cap correctly. Is this correct?
Thank you.
Old 6th January 2013, 05:51 PM   #2
1. Yes, you should use a decoupling cap there.
2. 118 k is correct, and neither the input cap not the previous stage play any part.
3. If you set the input cap correctly, you can get away with a 50 V rating as long as everything works well. I should still prefer a rating above rail voltage in case the amplifier blows and the full supply voltage becomes permanently present at pin 3.
If you've always done it like that, then it's probably wrong. (Henry Ford)
Old 6th January 2013, 10:51 PM   #3
Great. Thanks.
I'm looking for a LM3875 headphone circuit serenella Headphone Systems 5 19th November 2007 07:00 PM
LM3875 circuit ready to solder? ransom peek Chip Amps 26 26th May 2006 07:13 AM
Thoughts on circuit (IGC Lm3875) vindicare Chip Amps 0 10th June 2004 09:26 AM
Q about LM3875 circuit... Buhl Chip Amps 1 12th December 2003 01:49 PM
A way to match two LM3875 for a parallel circuit? NoKnowledge Chip Amps 15 2nd October 2003 08:54 PM
Copyright ©1999-2017 diyAudio
